Datasheet LTC3448 (Analog Devices) - 3
Описание1.5MHz/2.25MHz, 600mA Synchronous Step-Down Regulator with LDO Mode
Страниц / Страница20 / 3 — ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over …
Формат / Размер файлаPDF / 284 Кб
ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full operating
IC REG BUCK ADJ 600MA 8DFN. Buck Switching Regulator IC Positive Adjustable 0.6V 1 Output 600mA 8-WFDFN Exposed Pad. PMIC -...
LTC3448EDD#TRPBF
163 ₽
Рутоника
LTC3448EDD#TRPBF
215 ₽
LTC3448EDD#TRPBF
LifeElectronics
LTC3448EDD#TRPBF
LTC3448
denotes specifications which apply over the full operating temperature range, otherwise specifications are TA = 25
C. VIN = 3.6V unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IS Input DC Bias Current VIN = 3.6V (Note 5) Active Mode (Pulse Skip, No LRO) VFB = 0.5V or VOUT = 90%, ILOAD = 0A, 1.5MHz 250 375 µA VFB = 0.5V or VOUT = 90%, ILOAD = 0A, 2.25MHz 275 400 µA Linear Regulator Operation (LRO) ILOAD ≤ ILDO(ON) 32 43 µA Shutdown VRUN = 0V, VIN = 5.5V 0.1 1 µA fOSC Oscillator Frequency FREQ = Low, VIN = 3.6V ● 1.2 1.5 1.8 MHz FREQ = High ● 1.8 2.25 2.7 MHz fSYNC Synchronization Frequency (Note 6) 1.5 >4 MHz VTH(SYNC) SYNC Activation Input Threshold 1 1.3 V RPFET RDS(ON) of P-Channel FET ISW = 100mA 0.4 Ω RNFET RDS(ON) of N-Channel FET ISW = –150mA 0.35 Ω ILSW SW Leakage VRUN = 0V, VSW = 0V or 5V, VIN = 5V ±0.01 ±1 µA VRUNH RUN Threshold High ● 1.5 V VRUNL RUN Threshold Low ● 0.3 V IRUN RUN Leakage Current ● ±0.01 ±1 µA VFREQH FREQ Threshold High ● VIN – 1 V VFREQL FREQ Threshold Low ● 1 V IFREQ FREQ Leakage Current ● ±0.01 ±1 µA VMODEH MODE Threshold High ● VIN – 0.15 V VMODEL MODE Threshold Low ● 0.12 V IMODE MODE Leakage Current ● ±0.1 ±1 µA ISYNC SYNC Leakage Current ● ±0.01 ±1 µA ILDO(ON) LRO ON Load Current Threshold 2.2mH Inductor (Note 8) 3 5 mA ILDO(OFF) LRO OFF Load Current Threhold 8 11 17 mA
Note 1:
Absolute Maximum Ratings are those values beyond which the life
Note 6:
4MHz operation is guaranteed by design but is not production of a device may be impaired. tested and is subject to duty cycle limitations.
Note 2:
The LTC3448E is guaranteed to meet performance specifications
Note 7:
This IC includes overtemperature protection that is intended to from 0°C to 70°C. Specifications over the –40°C to 85°C operating protect the device during momentary overload conditions. Junction temperature range are assured by design, characterization and correlation temperature will exceed 125°C when overtemperature is active. Continu- with statistical process controls. ous operation above the specified maximum operating junction tempera-
Note 3:
T ture may impair device reliability. J is calculated from the ambient temperature TA and power dissipation PD according to the following formula:
Note 8:
The load current below which the switching regulator turns off and T the LDO turns on is, to first order, inversely proportional to the value of J = TA + (PD)(43°C/W)
Note 4:
The LTC3448 is tested in a proprietary test mode that connects the inductor. This effect is covered in more detail in the Operation section. V This parameter is not production tested but is guaranteed by design. FB to the output of the error amplifier.
Note 5:
Dynamic supply current is higher due to the gate charge being
Note 9:
For 2.5V < VIN < 2.7V the output voltage is limited to VIN – 0.7V delivered at the switching frequency. LRO is “linear regulator operation.” to ensure regulation in linear regulator mode. This parameter is not production tested but is guaranteed by design. 3448f 3
