Datasheet LT1933 (Analog Devices) - 2
Описание600mA, 500kHz Step-Down Switching Regulator in SOT-23 and DFN Packages
Страниц / Страница20 / 2 — ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION. …
Формат / Размер файлаPDF / 371 Кб
ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
26 предложений от 15 поставщиков
IC REG BUCK ADJ 600MA TSOT23-6. Buck Switching Regulator IC Positive Adjustable 1.245V 1 Output 600mA SOT-23-6 Thin, TSOT-23-6. PMIC -...
LT1933HS6#TRMPBF
190 ₽
LT1933HS6#TRMPBF
292 ₽
LT1933HS6#TRMPBF
МосЧип
LT1933HS6#TRMPBF
LT1933
LT1933I .. –40°C to 125°C Input Voltage (VIN) ... –0.4V to 36V LT1933H .. –40°C to 150°C BOOST Pin Voltage ...43V Maximum Junction Temperature BOOST Pin Above SW Pin ...20V LT1933E, LT1933I ... 125°C SHDN Pin ... –0.4V to 36V LT1933H ... 150°C FB Voltage .. –0.4V to 6V Storage Temperature Range .. –65°C to 150°C Operating Temperature Range (Note 2) Lead Temperature, S6 Package LT1933E ...–40°C to 85°C (Soldering, 10 sec) .. 300°C
PIN CONFIGURATION
TOP VIEW TOP VIEW BOOST 1 6 FB BOOST 1 6 SW V 2 7 5 GND IN GND 2 5 VIN SW 3 4 SHDN FB 3 4 SHDN S6 PACKAGE DCB PACKAGE 6-LEAD PLASTIC TSOT-23 6-LEAD (2mm × 3mm) PLASTIC DFN θ θ JA = 165°C/W, θJC = 102°C/W JA = 73.5°C/W, θJC = 12°C/W EXPOSED PAD (PIN 7) IS GND, MUST BE SOLDERED TO PCB
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LT1933IDCB#PBF LT1933IDCB#TRPBF LCGM 6-Lead (2mm × 3mm) Plastic DFN –40°C to 125°C LT1933HDCB#PBF LT1933HDCB#TRPBF LCGN 6-Lead (2mm × 3mm) Plastic DFN –40°C to 150°C LT1933ES6#PBF LT1933ES6#TRPBF LTAGN 6-Lead Plastic TSOT-23 –40°C to 85°C LT1933IS6#PBF LT1933IS6#TRPBF LTAGP 6-Lead Plastic TSOT-23 –40°C to 125°C LT1933HS6#PBF LT1933HS6#TRPBF LTDDQ 6-Lead Plastic TSOT-23 –40°C to 150°C
LEAD BASED FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LT1933IDCB LT1933IDCB#TR LCGM 6-Lead (2mm × 3mm) Plastic DFN –40°C to 125°C LT1933HDCB LT1933HDCB#TR LCGN 6-Lead (2mm × 3mm) Plastic DFN –40°C to 150°C LT1933ES6 LT1933ES6#TR LTAGN 6-Lead Plastic TSOT-23 –40°C to 85°C LT1933IS6 LT1933IS6#TR LTAGP 6-Lead Plastic TSOT-23 –40°C to 125°C LT1933HS6 LT1933HS6#TR LTDDQ 6-Lead Plastic TSOT-23 –40°C to 150°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/ 1933fe 2
