Datasheet LT1767, LT1767-1.8, LT1767-2.5, LT1767-3.3, LT1767-5 (Analog Devices) - 3
ОписаниеMonolithic 1.5A, 1.25MHz Step-Down Switching Regulators
Страниц / Страница20 / 3 — elecTrical characTerisTics The. denotes the specifications which apply …
Формат / Размер файлаPDF / 441 Кб
elecTrical characTerisTics The. denotes the specifications which apply over the full operating
elecTrical characTerisTics The denotes the specifications which apply over the full operating
35 предложений от 19 поставщиков
, Monolithic 1.5A, 1.25MHz Step-Down Switching Regulators
727GS
LT1767EMS8-3.3#TRPBF
от 182 ₽
Эиком
LT1767EMS8-5#TRPBF
от 908 ₽
LifeElectronics
LT1767EMS8E-2.5#TRPBF
TradeElectronics
LT1767/LT1767-1.8/ LT1767-2.5/LT1767-3.3/LT1767-5
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VIN = 15V, VC = 0.8V, Boost = VIN + 5V, SHDN, SYNC and switch open unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
Maximum Switch Current Limit TA = 0°C to 125°C 1.5 2 3 A TA = < 0°C 1.3 3 A Oscillator Frequency 3.3V < VIN < 25V 1.1 1.25 1.4 MHz l 1.1 1.5 MHz Switch On Voltage Drop ISW = –1.5A, 0°C ≤ TA ≤ 125°C and –1.3A, TA < 0°C 330 400 mV l 500 mV VIN Undervoltage Lockout (Note 3) l 2.47 2.6 2.73 V VIN Supply Current VFB = VNOM + 17% l 1 1.3 mA Shutdown Supply Current VSHDN = 0V, VIN = 25V, VSW = 0V 6 20 µA l 45 µA Feedback Voltage 3V < VIN < 25V, 0.4V < VC < 0.9V LT1767 (Adj) 1.182 1.2 1.218 V (Note 3) l 1.176 1.224 V LT1767-1.8 l 1.764 1.8 1.836 V LT1767-2.5 l 2.45 2.5 2.55 V LT1767-3.3 l 3.234 3.3 3.366 V LT1767-5 l 4.9 5 5.1 V FB Input Current LT1767 (Adj) l –0.25 –0.5 µA FB Input Resistance LT1767-1.8 l 10.5 15 21 kΩ LT1767-2.5 l 14.7 21 30 kΩ LT1767-3.3 l 19 27.5 39 kΩ LT1767-5 l 29 42 60 kΩ Error Amp Voltage Gain 0.4V < VC < 0.9V 150 350 Error Amp Transconductance ∆IVC = ±10µA l 500 850 1300 µMho VC Pin Source Current VFB = VNOM – 17% l 80 120 160 µA VC Pin Sink Current VFB = VNOM + 17% l 70 110 180 µA VC Pin to Switch Current Transconductance 2.5 A/V VC Pin Minimum Switching Threshold Duty Cycle = 0% 0.35 V VC Pin 1.5A ISW Threshold 0.9 V Maximum Switch Duty Cycle VC = 1.2V, ISW = 400mA 85 90 % l 80 % Minimum Boost Voltage Above Switch ISW = –1.5A, 0°C ≤ TA ≤ 125°C and –1.3A, TA < 0°C l 1.8 2.7 V Boost Current ISW = –0.5A (Note 4) l 10 15 mA ISW = –1.5A, 0°C ≤ TA ≤ 125°C and –1.3A, TA < 0°C (Note 4) l 30 45 mA SHDN Threshold Voltage l 1.27 1.33 1.40 V SHDN Input Current (Shutting Down) SHDN = 60mV Above Threshold l –7 –10 –13 µA SHDN Threshold Current Hysteresis SHDN = 100mV Below Threshold l 4 7 10 µA SYNC Threshold Voltage 1.5 2.2 V SYNC Input Frequency 1.5 2 MHz SYNC Pin Resistance ISYNC = 1mA 20 kΩ 1767fb For more information www.linear.com/LT1767 3 Document Outline Description Typical Application Absolute Maximum Ratings Electrical Characteristics Typical Application
