Datasheet LTC3838-1 (Analog Devices) - 3
ОписаниеDual, Fast, Accurate Step-Down DC/DC Controller with Dual Differential Output Sensing
Страниц / Страница54 / 3 — e lecTrical characTerisTics The. denotes the specifications which apply …
Формат / Размер файлаPDF / 890 Кб
e lecTrical characTerisTics The. denotes the specifications which apply over the specified operating
e lecTrical characTerisTics The denotes the specifications which apply over the specified operating
IC REG CTRLR BUCK 38QFN. Buck Regulator Positive Output Step-Down DC-DC Controller IC 38-QFN (5x7). PMIC - Voltage Regulators - DC...
LTC3838EUHF-1#TRPBF
256 ₽
Рутоника
LTC3838EUHF-1#TRPBF
324 ₽
LTC3838EUHF-1#TRPBF
462 ₽
LTC3838EUHF-1#TRPBF
LTC3838-1
l
denotes the specifications which apply over the specified operating junction temperature range, otherwise specifications are at TA = 25°C. VIN = 15V unless otherwise noted (Note 3). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Main Control Loops
VIN Input Voltage Operating Range 4.5 38 V VOUT1,2 Regulated Output Voltage Operating Range VOUT1 Regulated Differentially with 0.6 5.5 V Respect to V – OUTSENSE1 , VOUT2 Regulated Differentially with Respect to V – DFB2 IQ Input DC Supply Current Both Channels Enabled MODE/PLLIN = 0V, No Load 3 mA Only One Channel Enabled RUN1 or RUN2 (But Not Both) = 0V 2 mA Shutdown Supply Current RUN1 = RUN2 = 0V 15 µA V – FB1 Regulated Feedback Voltage on Channel 1 ITH1 = 1.2V, VOUTSENSE1 = 0V (Note 5) (V + – OUTSENSE1 – VOUTSENSE1 ) TA = 25°C 0.5985 0.6 0.6015 V TA = 0°C to 85°C l 0.596 0.6 0.604 V TA = –40°C to 125°C l 0.594 0.6 0.606 V Regulated Feedback Voltage on Channel 1 Over VIN = 4.5V to 38V, ITH1 = 0.5V to 1.9V, Line, Load and Common Mode –0.5V < V – OUTSENSE1 < 0.5V (Note 5) TA = 0°C to 85°C l 0.594 0.6 0.606 V TA = –40°C to 125°C l 0.591 0.6 0.609 V –0.2V < V – OUTSENSE1 < 0.2V TA = 0°C to 85°C l 0.5955 0.6 0.6045 V TA = –40°C to 125°C l 0.594 0.6 0.606 V V – FB2 Regulated Feedback Voltage on Channel 2 ITH2 = 1.2V, VDFB2 = 0V (Note 5) (2 • V + – DFB2 – VDFB2 ) TA = 25°C 0.598 0.6 0.602 V TA = 0°C to 85°C l 0.5955 0.6 0.6045 V TA = –40°C to 125°C l 0.594 0.6 0.606 V Regulated Feedback Voltage on Channel 2 Over VIN = 4.5V to 38V, ITH2 = 0.5V to 1.9V, Line, Load and Common Mode –0.2V < V – DFB2 < 0.2V (Note 5) TA = 0°C to 85°C l 0.5955 0.6 0.6045 V TA = –40°C to 125°C l 0.594 0.6 0.606 V I + + + – VOUTSENSE1 VOUTSENSE1 Input Bias Current VOUTSENSE1 = 0.6V, VOUTSENSE1 = 0V 0 ±25 nA I – – + – VOUTSENSE1 VOUTSENSE1 Input Bias Current VOUTSENSE1 = 0.6V, VOUTSENSE1 = 0V –25 –50 µA I + + + – VDFB2 VDFB2 Input Bias Current VDFB2 = 0.3V, VDFB2 = 0V 0 ±25 nA I – – + – VDFB2 VDFB2 Input Bias Current VDFB2 = 0.3V, VDFB2 = 0V –6 –12 µA gm(EA)1,2 Error Amplifier Transconductance (∆ITH1,2/∆VFB1,2) ITH = 1.2V (Note 5) 1.7 mS tON(MIN)1,2 Minimum Top Gate On-Time VIN = 38V, VOUT = 0.6V, RT = 20k (Note 6) 30 ns tOFF(MIN)1,2 Minimum Top Gate Off-Time (Note 6) 90 ns
Current Sensing
V – SENSE(MAX)1,2 Maximum Valley Current Sense Threshold VRNG = 0V, VFB = 0.57V, VSENSE = 2.5V l 24 30 36 mV (V + – – SENSE1,2 – VSENSE1,2 ) VRNG = INTVCC, VFB = 0.57V, VSENSE = 2.5V l 54 61 69 mV V – SENSE(MIN)1,2 Minimum Valley Current Sense Threshold VRNG = 0V, VFB = 0.63V, VSENSE = 2.5V –15 mV (V + – – SENSE1,2 – VSENSE1,2 ) VRNG = INTVCC, VFB = 0.63V, VSENSE = 2.5V –30 mV (Forced Continuous Mode) I + + SENSE1,2 SENSE1,2+ Pins Input Bias Current VSENSE = 0.6V ±5 ±50 nA V + SENSE = 5V 1 ±2 µA I – – SENSE1,2 SENSE1,2– Pins Input Bias Current (Internal 500k VSENSE = 0.6V 1.2 µA Resistor to SGND) V – SENSE = 5V 10 µA 38381fa For more information www.linear.com3838-1 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Pin Functions Functional Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
