Datasheet LTC3860 (Analog Devices) - 3
ОписаниеDual, Multiphase Step-Down Voltage Mode DC/DC Controller with Current Sharing
Страниц / Страница36 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 451 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
26 предложений от 18 поставщиков
LTC3860EUH#TRPBF
279 ₽
LTC3860EUH#PBF
753 ₽
Эиком
LTC3860EUH#PBF
от 764 ₽
Зенер
Россия и страны ТС
LTC3860EUH#TRPBF
811 ₽
LTC3860
l
denotes the specifi cations which apply over the full operating junction temperature range, otherwise specifi cations are at TA = 25°C (Note 3). VCC = 5V, VRUN1,2 = 5V, VFREQ = VCLKIN = 0V, VFB = 0.6V, fOSC = 0.6MHz unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
ISS Soft-Start Pin Output Current VSS = 0V 2.5 μA tSS(INTERNAL) Internal Soft-Start Time 2 ms VFB Regulated Feedback Voltage 0°C to 85°C 595.5 600 604.5 mV –40°C to 85°C 594 600 606 mV –40°C to 125°C l 592.5 600 607.5 mV ΔVFB/ΔVCC Regulated Feedback Voltage Line 3.0V < VCC < 5.5V 0.05 0.2 %/V Dependence ILIMIT ILIM Pin Output Current VILIM = 0.8V 18 20 22 μA
Power Good
VFB(OV) PGOOD/VFB Overvoltage Threshold VFB Falling 645 mV VFB Rising 650 660 670 mV VFB(UV) PGOOD/VFB Undervoltage Threshold VFB Falling 530 540 550 mV VFB Rising 555 mV VPGOOD(ON) PGOOD Pull-Down Resistance 15 60 Ω
Error Amplifi er
IFB FB Pin Input Current VFB = 600mV –100 100 nA IOUT COMP Pin Output Current Sourcing 1 mA Sinking 5 mA AV(OL) Open-Loop Voltage Gain 75 dB SR Slew Rate 45 V/μs f0dB COMP Unity-Gain Bandwidth 20 MHz
Differential Amplifi er
AV Differential Amplifi er Voltage Gain VVSNSN = 0V l 1.007 1 0.993 V/V VOS Input Referred Offset VVSNSN = 0V –2 2 mV SR Slew Rate 45 V/μs f0dB Bandwidth 20 MHz VOUT(MAX) Maximum Output Voltage 4 V
Current Sense Amplifi er
VISENSE(MAX) Maximum Differential Current Sense 50 mV Voltage (VISNSP-VISNSN) AV(ISENSE) Voltage Gain 18.5 V/V VCM(ISENSE) Input Common Mode Range –0.3 VCC + 0.1 V IISENSE SENSE Pin Input Current VCM = 1.5V 100 nA VOS Current Sense Input Referred Offset 0°C to 125°C –2 2 mV –40°C to 125°C l –2.2 2.2 mV
Oscillator and Phase-Locked Loop
fOSC Oscillator Frequency VCLKIN = 0V VFREQ = 0V l 360 400 440 kHz VFREQ = 5V l 540 600 660 kHz VCLKIN = 5V RFREQ < 24.9k 200 kHz RFREQ = 30.1k 300 kHz RFREQ = 54.9k 800 kHz RFREQ = 75.0k 1.2 MHz Maximum Frequency 1.25 MHz Minimum Frequency 0.25 MHz 3860fc 3 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION ELECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS PIN FUNCTIONS FUNCTIONAL DIAGRAM OPERATION APPLICATIONS INFORMATION TYPICAL APPLICATIONS PACKAGE DESCRIPTION REVISION HISTORY TYPICAL APPLICATION RELATED PARTS
