Datasheet LTC3736-1 (Analog Devices) - 2
Описание | Dual 2-Phase, No RSENSE , Synchronous Controller with Spread Spectrum |
Страниц / Страница | 28 / 2 — ABSOLUTE AXI U RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. ELECTRICAL … |
Формат / Размер файла | PDF / 541 Кб |
Язык документа | английский |
ABSOLUTE AXI U RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHARACTERISTICS The
37 предложений от 20 поставщиков Чип стабилизации напряжения, LINEAR TECHNOLOGY LTC3736EGN-1#PBF DC-DC Controller, Current Mode, 2-Phase, 2.75V to 9.8V, 2Outputs, Synchronous Buck, 825kHz, SSOP-24 |
| LTC3736EGN-1#PBF Analog Devices | от 192 ₽ | |
| LTC3736EGN-1 Linear Technology | 394 ₽ | |
| LTC3736EGN-1#TR Linear Technology | по запросу | |
| LTC3736EGN-1#TRPBF Analog Devices | по запросу | |
LTC3736-1
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Input Supply Voltage (VIN) .. – 0.3V to 10V TG1, TG2, BG1, BG2 Peak Output Current (<10µs) ... 1A FREQ, RUN/SS, SSDIS, Operating Temperature Range (Note 2) ... –40°C to 85°C TRACK, SENSE1+, SENSE2+, Storage Temperature Range .. –65°C to 125°C IPRG1, IPRG2 Voltages ... – 0.3V to (VIN + 0.3V) Junction Temperature (Note 3) .. 125°C VFB1, VFB2, ITH1, ITH2 Voltages .. – 0.3V to 2.4V Lead Temperature (Soldering, 10 sec) SW1, SW2 Voltages .. –2V to VIN + 1V or 10V Max (LTC3736EGN-1) .. 300°C PGOOD ... – 0.3V to 10V
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW ORDER PART ORDER PART + TOP VIEW NUMBER NUMBER SW1 1 24 SENSE1+ FB1V IPRG1 SW1 SENSE1 PGND BG1 IPRG1 2 23 PGND LTC3736EUF-1 LTC3736EGN-1 24 23 22 21 20 19 V 3 22 FB1 BG1 ITH1 1 18 SSDIS I 4 21 TH1 SSDIS IPRG2 2 17 TG1 IPRG2 5 20 TG1 FREQ 3 16 PGND 25 FREQ 6 19 PGND SGND 4 15 TG2 SGND 7 18 TG2 VIN 5 14 RUN/SS TRACK 6 13 BG2 V 8 17 IN RUN/SS UF PART MARKING TRACK 9 16 BG2 7 8 9 10 11 12 + V 10 15 FB2 PGND FB2 3736-1 V I TH2 SW2 PGND I 11 14 TH2 SENSE2+ PGOOD SENSE2 PGOOD 12 13 SW2 UF PACKAGE 24-LEAD (4mm × 4mm) PLASTIC QFN GN PACKAGE T 24-LEAD PLASTIC SSOP JMAX = 125°C, θJA = 37°C/W EXPOSED PAD (PIN 25) IS PGND TJMAX = 125°C, θJA = 130°C/ W MUST BE SOLDERED TO PCB Consult LTC Marketing for parts specified with wider operating temperature ranges.
denotes specifications that apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VIN = 4.2V unless otherwise specified. PARAMETER CONDITIONS MIN TYP MAX UNITS Main Control Loops
Input DC Supply Current (Note 4) Normal Mode 500 850 µA Shutdown RUN/SS = 0V 9 20 µA UVLO VIN < UVLO Threshold 3 10 µA Undervoltage Lockout Threshold VIN Falling ● 1.95 2.25 2.55 V VIN Rising ● 2.15 2.45 2.75 V Shutdown Threshold at RUN/SS 0.45 0.65 0.85 V Start-Up Current Source RUN/SS = 0V 0.5 0.7 1 µA Regulated Feedback Voltage 0°C to 85°C (Note 5) 0.591 0.6 0.609 V –40°C to 85°C ● 0.588 0.6 0.612 V Output Voltage Line Regulation 2.75V < VIN < 9.8V (Note 5) 0.05 0.2 mV/V 37361f 2
