Оптопары и оптореле Megawin
Datasheet LTC3737 (Analog Devices) - 2
ОписаниеDual 2-Phase, No RSENSE  DC/DC Controller with Output Tracking
Страниц / Страница24 / 2 — ABSOLUTE AXI U RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. ELECTRICAL …
Формат / Размер файлаPDF / 282 Кб
ABSOLUTE AXI U RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHARACTERISTICS The
ABSOLUTE AXI U RATI GS (Note 1) PACKAGE/ORDER I FOR ATIO ELECTRICAL CHARACTERISTICS The
Buck Regulator Positive Output Step-Down DC-DC Controller IC 24-SSOP
LTC3737EGN#TRPBF
294 ₽
727GS
LTC3737EGN#TRPBF
от 987 ₽
LTC3737EGN#TRPBF
Hi-Tech Circuit Group
LTC3737EGN#TRPBF
LTC3737
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Input Supply Voltage (VIN), PVIN1, PVIN2, Operating Temperature Range (Note 2) ... –40°C to 85°C SENSE1+, SENSE2+ .. – 0.3V to 10V Storage Ambient Temperature Range PGATE1, PGATE2, PLLLPF, RUN/SS, SYNC/MODE, QFN Package .. –65°C to 125°C TRACK, IPRG1, IPRG2 Voltages .. – 0.3V to (VIN + 0.3V) SSOP Package .. –65°C to 150°C VFB1, VFB2, ITH1, ITH2 Voltages .. – 0.3V to 2.4V Junction Temperature (Note 3) .. 125°C SW1, SW2 Voltages .. –2V to VIN + 1V or 10V Max Lead Temperature (Soldering, 10sec) PGOOD ... – 0.3V to 10V LTC3737EGN ... 300°C PGATE1, PGATE2 Peak Output Current (<10µs) ... 1A
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW TOP VIEW ORDER PART ) ORDER PART – + SW1 NUMBER NUMBER 1 24 SENSE1+ (SENSE1–) IN1 FB1V IPRG1 SW1 (SENSE1 SENSE1 PV NC IPRG1 2 23 PVIN1 LTC3737EGN LTC3737EUF 24 23 22 21 20 19 V 3 22 FB1 NC SYNC/ ITH1 1 18 I 4 21 SYNC/MODE MODE TH1 IPRG2 2 17 PGATE1 IPRG2 5 20 PGATE1 PLLLPF 3 16 PGND PLLLPF 6 19 PGND 25 SGND 4 15 PGATE2 SGND 7 18 PGATE2 VIN 5 14 RUN/SS V 8 17 IN RUN/SS TRACK 6 13 NC UF PART TRACK 9 16 NC MARKING 7 8 9 10 11 12 V 10 15 FB2 PVIN2 ) + – FB2 IN2 I 11 14 TH2 SENSE2+ V I TH2 SW2 PV 3737 SW2 PGOOD PGOOD 12 13 SENSE2 (SENSE2–) (SENSE2 UF PACKAGE GN PACKAGE 24-LEAD (4mm × 4mm) PLASTIC QFN 24-LEAD (NARROW) PLASTIC SSOP T T JMAX = 125°C, θJA = 37°C/W JMAX = 125°C, θJA = 130°C/W EXPOSED PAD IS PGND (PIN 25) MUST BE SOLDERED TO PCB Consult LTC Marketing for parts specified with wider operating temperature ranges.
denotes specifications that apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VIN = 4.2V unless otherwise specified. PARAMETER CONDITIONS MIN TYP MAX UNITS Main Control Loops
Input DC Supply Current (Note 4) Sleep Mode 220 325 µA Shutdown RUN/SS = 0V 9 20 µA UVLO VIN < UVLO Threshold –200mV 3 10 µA Undervoltage Lockout Threshold VIN Falling ● 1.95 2.25 2.55 V VIN Rising ● 2.15 2.45 2.75 V Shutdown Threshold at RUN/SS 0.45 0.65 0.85 V Start-Up Current Source RUN/SS = 0V 0.4 0.7 1 µA Regulated Feedback Voltage 0°C to 85°C (Note 5) 0.591 0.6 0.609 V –40°C to 85°C ● 0.588 0.6 0.612 V Output Voltage Line Regulation 2.75V < VIN < 9.8V (Note 5) 0.05 0.2 mV/V 3737fa 2
