Datasheet LTC3707-SYNC (Analog Devices) - 3
ОписаниеHigh Efficiency, 2-Phase Synchronous Step-Down Switching Regulator
Страниц / Страница32 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 404 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
High Effi ciency, 2-Phase Synchronous Step-Down Switching Regulator
LifeElectronics
LTC3707IGN-SYNC-TRPBF
LTC3707IGN-SYNC TRPBF
LTC3707-SYNC
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 15V, VRUN/SS1, 2 = 5V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
gmGBW1, 2 Transconductance Amplifi er GBW ITH1, 2 = 1.2V; (Note 4) 3 MHz IQ Input DC Supply Current (Note 5) Normal Mode VIN = 15V; EXTVCC Tied to VOUT1; VOUT1 = 5V 350 μA Shutdown VRUN/SS1, 2 = 0V, VSTBYMD = Open 20 35 μA VFCB Forced Continuous Threshold l 0.76 0.800 0.84 V IFCB Forced Continuous Pin Current VFCB = 0.85V –0.30 –0.18 –0.1 μA VBINHIBIT Burst Inhibit (Constant Frequency) Measured at FCB pin 4.3 4.8 V Threshold UVLO Undervoltage Lockout VIN Ramping Down l 3.5 4 V VOVL Feedback Overvoltage Lockout Measured at VOSENSE1, 2 l 0.84 0.86 0.88 V ISENSE Sense Pins Total Source Current (Each Channel); VSENSE1–, 2– = VSENSE1+, 2+ = 0V –90 –60 μA DFMAX Maximum Duty Factor In Dropout 98 99.4 % IRUN/SS1, 2 Soft-Start Charge Current VRUN/SS1, 2 = 1.9V 0.5 1.2 μA VRUN/SS1, 2 ON RUN/SS Pin ON Threshold VRUN/SS1, VRUN/SS2 Rising 1.0 1.5 2.0 V VRUN/SS1, 2 LT RUN/SS Pin Latchoff Arming Threshold VRUN/SS1, VRUN/SS2 Rising from 3V 4.1 4.75 V ISCL1, 2 RUN/SS Discharge Current Soft Short Condition VOSENSE1, 2 = 0.5V; 0.5 2 4 μA VRUN/SS1, 2 = 4.5V ISDLHO Shutdown Latch Disable Current VOSENSE1, 2 = 0.5V 1.6 5 μA VSENSE(MAX) Maximum Current Sense Threshold VOSENSE1, 2 = 0.7V,VSENSE1–, 2– = 5V 65 75 85 mV VOSENSE1, 2 = 0.7V,VSENSE1–, 2– = 5V l 62 75 88 mV TG Transition Time: (Note 6) TG1, 2 tr Rise Time CLOAD = 3300pF 60 110 ns TG1, 2 tf Fall Time CLOAD = 3300pF 60 110 ns BG Transition Time: (Note 6) BG1, 2 tr Rise Time CLOAD = 3300pF 50 110 ns BG1, 2 tf Fall Time CLOAD = 3300pF 50 100 ns TG/BG t1D Top Gate Off to Bottom Gate On Delay Synchronous Switch-On Delay Time CLOAD = 3300pF Each Driver 80 ns BG/TG t2D Bottom Gate Off to Top Gate On Delay Top Switch-On Delay Time CLOAD = 3300pF Each Driver 80 ns tON(MIN) Minimum On-Time Tested with a Square Wave (Note 7) 180 ns
INTVCC Linear Regulator
VINTVCC Internal VCC Voltage 6V < VIN < 30V, VEXTVCC = 4V 4.8 5.0 5.2 V VLDO INT INTVCC Load Regulation ICC = 0 to 20mA, VEXTVCC = 4V 0.2 2.0 % VLDO EXT EXTVCC Voltage Drop ICC = 20mA, VEXTVCC = 5V 100 200 mV VEXTVCC EXTVCC Switchover Voltage ICC = 20mA, EXTVCC Ramping Positive l 4.5 4.7 V VLDOHYS EXTVCC Hysteresis 0.2 V
Oscillator and Phase-Locked Loop
fNOM Nominal Frequency VPLLFLTR = 1.2V 190 220 250 kHz fLOW Lowest Frequency VPLLFLTR = 0V 120 140 160 kHz fHIGH Highest Frequency VPLLFLTR ≥ 2.4V 280 310 360 kHz RPLLIN PLLIN Input Resistance 50 kΩ 3707sfa 3
