Линейка продуктов KEEN SIDE
Datasheet LTM4623 (Analog Devices) - 2
ОписаниеUltrathin 20VIN, 3A Step-Down DC/DC µModule Regulator
Страниц / Страница28 / 2 — (Note 1). (See Pin Functions, Pin Configuration T. able). PART MARKING*. …
ВерсияD
Формат / Размер файлаPDF / 305 Кб
(Note 1). (See Pin Functions, Pin Configuration T. able). PART MARKING*. PACKAGE. MSL. TEMPERATURE RANGE. PART NUMBER
(Note 1) (See Pin Functions, Pin Configuration T able) PART MARKING* PACKAGE MSL TEMPERATURE RANGE PART NUMBER
24 предложений от 10 поставщиков
Преобразователь DC/DC, Conv DC-DC 4V to 20V Step Down Single-Out 0.6V to 5.5V 3A uModule 25Pin LGA
LTM4623EV#PBF
от 683 ₽
LTM4623EV#PBF
863 ₽
Элитан
LTM4623EV
1 749 ₽
LTM4623EV#PBF
от 1 853 ₽
LTM4623 ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION
VIN, SVIN .. –0.3V to 22V V TOP VIEW OUT ...–0.3V to SVIN or 6V CLKOUT RUN ... –0.3V to 22V CLKIN SVIN INTVCC .. –0.3V to 3.6V 5 VIN SGND PGOOD, MODE, TRACK/SS, FREQ, MODE FREQ 4 INTVCC PHMODE, CLKIN .. –0.3V to INTV RUN CC 3 GND Internal Operating Junction Temperature Range PHMODE TRACK/SS PGOOD 2 (Notes 2, 5) .. –40°C to 125°C FB VOUT COMP 1 Storage Temperature Range .. –65°C to 150°C Peak Solder Reflow Body Temperature ...260°C A B C D E LGA PACKAGE 25-LEAD (6.25mm × 6.25mm × 1.82mm) BGA PACKAGE 25-LEAD (6.25mm × 6.25mm × 2.42mm) TJMAX = 125°C, θJCtop = 17°C/W, θJCbottom = 11°C/W, θJB + θBA = 22°C/W, θJA = 22°C/W, θJA DERIVED FROM 95mm × 76mm PCB WITH 4 LAYERS θ VALUES DETERMINED PER JESD51-12, WEIGHT = 0.5g ORDER INFORMATION
PART MARKING* PACKAGE MSL TEMPERATURE RANGE PART NUMBER PAD OR BALL FINISH DEVICE FINISH CODE TYPE RATING (Note 2)
LTM4623EV#PBF Au (RoHS) LTM4623V e4 LGA 3 –40°C to 125°C LTM4623IV#PBF Au (RoHS) LTM4623V e4 LGA 3 –40°C to 125°C LTM4623EY#PBF SAC305 (RoHS) LTM4623Y e1 BGA 3 –40°C to 125°C LTM4623IY#PBF SAC305 (RoHS) LTM4623Y e1 BGA 3 –40°C to 125°C LTM4623IY SnPb (63/37) LTM4623Y e0 BGA 3 –40°C to 125°C • Consult Marketing for parts specified with wider operating temperature • Recommended LGA and BGA PCB Assembly and Manufacturing ranges. *Pad or ball finish code is per IPC/JEDEC J-STD-609. Procedures • LGA and BGA Package and Tray Drawings Rev D 2 For more information www.analog.com Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Decoupling Requirements Operation Applications Information Package Description Revision History Package Photos Design Resources Related Parts
