Datasheet BD135G, BD137G, BD139G (ON Semiconductor) - 2
Производитель | ON Semiconductor |
Описание | Plastic Medium-Power Silicon NPN Transistors |
Страниц / Страница | 4 / 2 — BD135G, BD137G, BD139G. ELECTRICAL CHARACTERISTICS. Characteristic. … |
Версия | 17 |
Формат / Размер файла | PDF / 82 Кб |
Язык документа | английский |
BD135G, BD137G, BD139G. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Min. Max. UnIt. TYPICAL CHARACTERISTICS
35 предложений от 15 поставщиков Биполярный транзистор, NPN, 45 В, 1.5 А, 1.25 Вт, TO-225, Through Hole |
| BD135G ON Semiconductor | от 6.90 ₽ | |
| BD135G ON Semiconductor | 24 ₽ | |
| BD135G ON Semiconductor | от 78 ₽ | |
| BD135G ON Semiconductor | 125 ₽ | |
BD135G, BD137G, BD139G ELECTRICAL CHARACTERISTICS
(TC = 25_C unless otherwise noted)
Characteristic Symbol Min Max UnIt
Collector−Emitter Sustaining Voltage* BVCEO* Vdc (IC = 0.03 Adc, IB = 0) BD135G 45 − BD137G 60 − BD139G 80 − Collector Cutoff Current ICBO mAdc (VCB = 30 Vdc, IE = 0) − 0.1 (VCB = 30 Vdc, IE = 0, TC = 125_C) − 10 Emitter Cutoff Current IEBO − 10 mAdc (VBE = 5.0 Vdc, IC = 0) DC Current Gain hFE* − (IC = 0.005 A, VCE = 2 V) 25 − (IC = 0.15 A, VCE = 2 V) 40 250 (IC = 0.5 A VCE = 2 V) 25 − Collector−Emitter Saturation Voltage* VCE(sat)* Vdc (IC = 0.5 Adc, IB = 0.05 Adc) − 0.5 Base−Emitter On Voltage* VBE(on)* Vdc (IC = 0.5 Adc, VCE = 2.0 Vdc) − 1 Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. *Pulse Test: Pulse Width ≤ 300 ms, Duty Cycle ≤ 2.0%.
1000 0.3 VCE = 2 V IC/IB = 10 150°C 150°C AGE (V) 0.2 T 25°C OR−EMITTER −55°C 100 −55°C 25°C TION VOL 0.1 , DC CURRENT GAIN , COLLECT FE TURA h SA CE(sat)V 10 0 0.001 0.01 0.1 1 10 0.001 0.01 0.1 1 10 IC, COLLECTOR CURRENT (A) IC, COLLECTOR CURRENT (A)
Figure 1. DC Current Gain Figure 2. Collector−Emitter Saturation Voltage http://onsemi.com 2
