Datasheet LTC3785-1 (Analog Devices) - 2
Описание10V, High Efficiency, Buck-Boost Controller with Power Good
Страниц / Страница20 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
Формат / Размер файлаPDF / 224 Кб
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
39 предложений от 19 поставщиков
IC: PMIC; преобразователь DC/DC; Uвх: 2,7÷10ВDC; Uвых: 2,7÷10ВDC
LTC3785EUF-1#PBF
от 158 ₽
LTC3785EUF-1#PBF
286 ₽
727GS
LTC3785EUF-1#TRPBF
от 829 ₽
LifeElectronics
LTC3785EUF-1#PBF
LTC3785-1
Input Supply Voltage (V TOP VIEW IN) ... –0.3V to 11V I IN CC BST1 SVOUT, ISVIN .. –0.3V to 11V V V I SVIN V TG1 SW1 SW1, SW2, I 24 23 22 21 20 19 SSW1, ISSW2 Voltage: DC ... –1V to 11V RUN/SS 1 18 ISSW1 Pulsed, <1μs ... –2V to 12V VC 2 17 BG1 FB 3 16 V RUN/SS, MODE, CCM, V DRV DRV, VCC Voltages .. –0.3V to 6V 25 V 4 15 SENSE BG2 PGOOD Voltage .. –0.3V to 6V ILSET 5 14 ISSW2 VBST1 Voltage ... –0.3V to 16V CCM 6 13 SW2 With Respect to SW1 ... –0.3V to 6V 7 8 9 10 11 12 VBST2 Voltage ... –0.3V to 16V RT With Respect to SW2 ... –0.3V to 6V BST2 TG2 MODE PGOOD I SVOUT V Peak Driver Output Current < 10μs UF PACKAGE (TG1, TG2, BG1, BG2) ...3A 24-LEAD (4mm s 4mm) PLASTIC QFN TJMAX = 125°C, θJA = 37°C/W 4 LAYER BOARD VCC Average Output Current ...100mA EXPOSED PAD (PIN 25) IS GND, MUST BE SOLDERED TO PCB Operating Temperature Range (Note 2).. –40°C to 85°C Junction Temperature ... 125°C Storage Temperature Range ... –65°C to 125°C
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3785EUF-1#PBF LTC3785EUF-1#TRPBF 37851 24-Lead (4mm × 4mm) Plastic QFN –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
ELECTRICAL CHARACTERISTICS The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = ISVOUT = VDRV = VBST1 = VBST2 = 3.6V, RT = 49.9k, RILSET = 59k. PARAMETER CONDITIONS MIN TYP MAX UNITS VIN Supply
Input Operating Voltage l 2.7 10 V Quiescent Current—Burst Mode Operation VC = 0V, MODE = 3.6V (Note 4) 86 200 μA Quiescent Current—Shutdown RUN/SS = 0V, ISVOUT = 3.6V 15 25 μA Quiescent Current—Active MODE = 0V (Note 4) 0.8 1.5 mA
Error Amp
Feedback Voltage (Note 5) l 1.200 1.225 1.25 V Feedback Input Current 1 500 nA Error Amp Source Current –500 μA Error Amp Sink Current 900 μA Error Amp AVOL 90 dB 37851fa 2
