Datasheet LTM4700 (Analog Devices) - 7
ОписаниеDual 50A or Single 100A µModule Regulator with Digital Power System Management
Страниц / Страница126 / 7 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
Формат / Размер файлаPDF / 2.9 Мб
ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply over the specified internal
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the specified internal
24 предложений от 12 поставщиков
DUAL 50A, SINGLE 100A M REG. Non-Isolated PoL Module DC DC Converter 2 Output 0.5 ~ 1.8V 0.5 ~ 1.8V 50A,...
LTM4700IY#PBF
от 4 482 ₽
LTM4700IY#PBF
5 468 ₽
Зенер
Россия и страны ТС
LTM4700IY#PBF
от 12 543 ₽
Элитан
LTM4700IY
30 346 ₽
LTM4700
l
denotes the specifications which apply over the specified internal operating temperature range (Note 2). Specified as each individual output channel (Note 4). TA = 25°C, VIN = 12V, RUNn = 3.3V, FREQUENCY_SWITCH = 350kHz and VOUTn commanded to 1.000V unless otherwise noted. Configured with factory-default EEPROM settings and per Test Circuit 1, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
V + – UV-ACC Output UV Comparator Threshold 1V ≤ VVOSNS0 – VVOSNS0 ≤ 1.8V, MFR_PWM_MODE0[1] = 1b l ±1.5 % Accuracy (See Note 14) 0.5V ≤ V + – VSNS0 – VVSNS0 < 1V, MFR_PWM_MODE0[1] = 1b l ±30 mV 1V ≤ V + – VOSNS1 – VVOSNS1 ≤ 1.8V, MFR_PWM_MODE1[1] = 1b l ±1.5 % 0.5V ≤ V + – VOSNS1 – VVOSNS1 < 1V, MFR_PWM_MODE1[1] = 1b l ±30 mV tPROP-OV Output OV Comparator Response Overdrive to 10% Above Programmed Threshold 100 µs Times tPROP-UV Output UV Comparator Response Under Drive to 10% Below Programmed Threshold 100 µs Times
Analog OV/UV SVIN Input Voltage Supervisor Comparators (Threshold Detectors for VIN_ON and VIN_OFF)
NSVIN-OV/UV-COMP SVIN OV/UV Comparator Threshold- (Notes 14, 15) 9 Bits Programming Resolution SVIN-OU-RANGE SVIN OV/UV Comparator Threshold- l 4.5 18 V Programming Range SVIN-OU-STP SVIN OV/UV Comparator Threshold- (Note 15) 76 mV Programming LSB Step Size SVIN-OU-ACC SVIN OV/UV Comparator Threshold 9V < SVIN ≤ 16V l ±3 % Accuracy 4.5V ≤ SVIN ≤ 9V l ±225 mV tPROP-SVIN-HIGH-VIN SVIN OV/UV Comparator Response Test Circuit 1, and: Time, High VIN Operating VIN_ON = 9V; SVIN Driven from 8.775V to 9.225V l 100 µs Configuration VIN_OFF = 9V; SVIN Driven from 9.225V to 8.775V l 100 µs tPROP-SVIN-LOW-VIN SVIN OV/UV Comparator Response Test Circuit 2, and: Time, Low VIN Operating VIN_ON = 4.5V; SVIN Driven from 4.225V to 4.725V l 100 µs Configuration VIN_OFF = 4.5V; SVIN Driven from 4.725V to 4.225V l 100 µs
Channels 0 and 1 Output Voltage Readback (READ_VOUTn )
NVO-RB Output Voltage Readback (Note 15) 16 Bits Resolution and LSB Step Size 244 µV VO-F/S Output Voltage Full-Scale Digitizable VRUNn = 0V (Note 15) 8 V Range V + – O-RB-ACC Output Voltage Readback Accuracy Channel 0: 1V ≤ VVOSNS0 – VVOSNS0 ≤ 1.8V l Within ±0.5% of Reading Channel 0: 0.5V ≤ V + – VOSNS0 – VVOSNS0 < 1V (Note 15) l Within ±5mV of Reading Channel 1: 1V ≤ V + – VOSNS1 – VVOSNS1 ≤ 1.8V l Within ±0.5% of Reading Channel 1: 0.5V ≤ V + – VOSNS1 – VVOSNS1 < 1V l Within ±5mV of Reading tCONVERT-VO-RB Output Voltage Readback Update MFR_ADC_CONTROL = 0x00 (Notes 9, 15) 90 ms Rate MFR_ADC_CONTROL = 0x01 through 0x0C (Notes 9, 15) 8 ms MFR_ADC_CONTROL Section ms
Input Voltage (SVIN) Readback (READ_VIN)
NSVIN-RB Input Voltage Readback Resolution (Notes 10, 15) 10 Bits and LSB Step Size 15.625 mV SVIN-F/S Input Voltage Full-Scale Digitizable (Notes 11, 15) 43 V Range SVIN-RB-ACC Input Voltage Readback Accuracy READ_VIN, 4.5V ≤ SVIN ≤ 16V l Within ±2% of Reading tCONVERT-SVIN-RB Input Voltage Readback Update MFR_ADC_CONTROL = 0x00 (Notes 9, 15) 90 ms Rate MFR_ADC_CONTROL = 0x01 (Notes 9, 15) 8 ms Rev 0 For more information www.analog.com 7 Document Outline Features Applications Typical Application Description Table of Contents Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Block Diagram Decoupling Requirements Functional Diagram Test Circuits Operation PMBus Command Summary Applications Information Applications Information-Derating Curves Typical Applications PMBus Command Details Package Description Typical Applications Package Photograph Related Parts Features Applications Typical Application Description Table of Contents Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Block Diagram Decoupling Requirements Functional Diagram Test Circuits Operation Power Module Introduction Power Module Overview, Major Features EEPROM with ECC Power-Up and Initialization Soft-Start Time-Based Sequencing Voltage-Based Sequencing Shutdown Light-Load Current Operation Switching Frequency and Phase PWM Loop Compensation Output Voltage Sensing INTVCC and Build-in 5V Bias Converter Output Current Sensing and Sub Milliohm DCR Current Sensing Input Current Sensing PolyPhase Load Sharing External/Internal Temperature Sense RCONFIG (Resistor Configuration) Pins Fault Detection and Handling Status Registers and ALERT Masking Mapping Faults to FAULT Pins Power Good Pins CRC Protection Serial Interface Communication Protection Device Addressing Responses to VOUT and IIN/IOUT Faults Output Overvoltage Fault Response Output Undervoltage Response Peak Output Overcurrent Fault Response Responses to Timing Faults Responses to VIN OV Faults Responses to OT/UT Faults Internal Overtemperature Fault Response External Overtemperature and Undertemperature Fault Response Responses to Input Overcurrent and Output Undercurrent Faults Responses to External Faults Fault Logging Bus Timeout Protection Similarity Between PMBus, SMBus and I2C 2-Wire Interface PMBus Serial Digital Interface Figures 7 to 24 PMBus Protocols PMBus Command Summary PMBus Commands Applications Information VIN to VOUT Step-Down Ratios Input Capacitors Output Capacitors Light Load Current Operation Switching Frequency and Phase Output Current Limit Programming Minimum On-Time Considerations Variable Delay Time, Soft-Start and Output Voltage Ramping Digital Servo Mode Soft Off (Sequenced Off) Undervoltage Lockout Fault Detection and Handling Open-Drain Pins Phase-Locked Loop and Frequency Synchronization Input Current Sense Amplifier Programmable Loop Compensation Checking Transient Response PolyPhase Configuration Connecting The USB to I2C/SMBus/PMBus Controller to the LTM4700 In System LTpowerPlay: An Interactive GUI for Digital Power PMBus Communication and Command Processing Thermal Considerations and Output Current Derating Applications Information-Derating Curves EMI Performance Safety Considerations Layout Checklist/Example Typical Applications PMBus Command Details Addressing and Write Protect General Configuration Commands On/Off/Margin PWM Configuration Voltage Input Voltage and Limits Output Voltage and Limits Output Current and Limits Input Current and Limits Temperature External Temperature Calibration Timing Timing—On Sequence/Ramp Timing—Off Sequence/Ramp Precondition for Restart Fault Response Fault Responses All Faults Fault Responses Input Voltage Fault Responses Output Voltage Fault Responses Output Current Fault Responses IC Temperature Fault Responses External Temperature Fault Sharing Fault Sharing Propagation Fault Sharing Response Scratchpad Identification Fault Warning and Status Telemetry NVM Memory Commands Store/Restore Fault Logging Block Memory Write/Read Package Description Typical Applications Package Photograph Related Parts
