Datasheet LTC2333-18 (Analog Devices) - 5
ОписаниеBuffered 8-Channel, 18-Bit, 800ksps Differential ±10.24V ADC with 30VP-P Common Mode Range
Страниц / Страница40 / 5 — REFERENCE BUFFER CHARACTERISTICS. The. denotes the specifications which …
REFERENCE BUFFER CHARACTERISTICS. The. denotes the specifications which apply over the full
REFERENCE BUFFER CHARACTERISTICS The denotes the specifications which apply over the full
20 предложений от 13 поставщиков
IC ADC 18BIT SAR 48LQFP. 18 Bit Analog to Digital Converter 8 Input 1 SAR 48-LQFP (7x7). Data Acquisition - Analog...
LTC2333CLX-18#PBF
996 ₽
Зенер
Россия и страны ТС
LTC2333CLX-18#PBF
от 2 675 ₽
LTC2333CLX-18#PBF
3 308 ₽
Эиком
LTC2333CLX-18#PBF
от 6 315 ₽
LTC2333-18
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 9) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VREFBUF Reference Buffer Output Voltage REFIN Overdriven, VREFIN = 2.048V l 4.091 4.096 4.101 V REFBUF Voltage Range REFBUF Overdriven (Notes 7, 15) l 2.5 5 V REFBUF Input Impedance VREFIN = 0V, Buffer Disabled 13 kΩ IREFBUF REFBUF Load Current VREFBUF = 5V, (Notes 15, 16) l 0.93 1.2 mA VREFBUF = 5V, Acquisition or Nap Mode (Note 15) 0.39 mA
DIGITAL INPUTS AND DIGITAL OUTPUTS The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 9) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS CMOS Digital Inputs and Outputs
VIH High Level Input Voltage l 0.8 • OVDD V VIL Low Level Input Voltage l 0.2 • OVDD V IIN Digital Input Current VIN = 0V to OVDD l –10 10 μA CIN Digital Input Capacitance 5 pF VOH High Level Output Voltage IOUT = –500μA l OVDD – 0.2 V VOL Low Level Output Voltage IOUT = 500μA l 0.2 V IOZ Hi-Z Output Leakage Current VOUT = 0V to OVDD l –10 10 μA ISOURCE Output Source Current VOUT = 0V –50 mA ISINK Output Sink Current VOUT = OVDD 50 mA
LVDS Digital Inputs and Outputs
VID Differential Input Voltage l 200 350 600 mV RID On-Chip Input Termination CS = 0V, VICM = 1.2V l 90 106 125 Ω Resistance CS = OVDD 10 MΩ VICM Common-Mode Input Voltage l 0.3 1.2 2.2 V IICM Common-Mode Input Current VIN+ = VIN– = 0V to OVDD l –10 10 μA VOD Differential Output Voltage RL = 100Ω Differential Termination l 275 350 425 mV VOCM Common-Mode Output Voltage RL = 100Ω Differential Termination l 1.1 1.2 1.3 V IOZ Hi-Z Output Leakage Current VOUT = 0V to OVDD l –10 10 μA 233318f For more information www.linear.com/LTC2333-18 5
