Datasheet ADM3053 (Analog Devices) - 6
ОписаниеSignal and Power Isolated CAN Transceiver with Integrated Isolated DC-to-DC Converter
Страниц / Страница18 / 6 — ADM3053. Data Sheet. VDE 0884 INSULATION CHARACTERISTICS. Table 5. …
ВерсияE
Формат / Размер файлаPDF / 527 Кб
ADM3053. Data Sheet. VDE 0884 INSULATION CHARACTERISTICS. Table 5. Description. Test Conditions/Comments
ADM3053 Data Sheet VDE 0884 INSULATION CHARACTERISTICS Table 5 Description Test Conditions/Comments
50 предложений от 23 поставщиков
Цифровые изоляторы.Тип: CAN-трансивер изолированный со встроенным DC-DC преобразователемВес брутто: 1.33Транспортная упаковка: размер/кол-во: 60*50*50/400Напряжение питания: 4.5…5,5 (max) ВДиапазон рабочих температур: -40…+85 °ССкорость...
ADM3053BRWZ-REEL7
1 017 ₽
727GS
ADM3053BRWZ-REEL7
ADM3053BRWZ-REEL7
Hi-Tech Circuit Group
ADM3053BRWZ-REEL7
link to page 5
This isolator is suitable for basic electrical isolation only within the safety limit data. Maintenance of the safety data must be ensured by means of protective circuits.
Table 5. Description Test Conditions/Comments Symbol Characteristic Unit
CLASSIFICATIONS Installation Classification per DIN VDE 0110 for Rated Mains Voltage ≤150 V rms I to IV ≤300 V rms I to III ≤400 V rms I to II Climatic Classification 40/85/21 Pollution Degree DIN VDE 0110, see Table 3 2 VOLTAGE Maximum Working Insulation Voltage VIORM 560 VPEAK Input-to-Output Test Voltage VPR Method b1 VIORM × 1.875 = VPR, 100% production tested, 1050 VPEAK tm = 1 sec, partial discharge < 5 pC Highest Allowable Overvoltage (Transient overvoltage, tTR = 10 sec) VTR 4000 VPEAK SAFETY-LIMITING VALUES Maximum value allowed in the event of a failure Case Temperature TS 150 °C Input Current IS, INPUT 265 mA Output Current IS, OUTPUT 335 mA Insulation Resistance at TS VIO = 500 V RS >109 Ω Rev. E | Page 6 of 18 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS SWITCHING CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY-RELATED SPECIFICATIONS VDE 0884 INSULATION CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS CIRCUIT DESCRIPTION CAN TRANSCEIVER OPERATION SIGNAL ISOLATION POWER ISOLATION TRUTH TABLES THERMAL SHUTDOWN DC CORRECTNESS AND MAGNETIC FIELD IMMUNITY APPLICATIONS INFORMATION PCB LAYOUT EMI CONSIDERATIONS RS PIN INSULATION LIFETIME TYPICAL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
