Datasheet LT3091 (Analog Devices) - 2
Описание–36V, 1.5A Negative Linear Regulator with Programmable Current Limit
Страниц / Страница40 / 2 — absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion
Формат / Размер файлаPDF / 756 Кб
absoluTe MaxiMuM raTings (Note 1) pin conFiguraTion
22 предложений от 13 поставщиков
Интегральные микросхемы Силовые чипы — регуляторы напряжения — линейные
LT3091MPDE#TRPBF
344 ₽
LT3091MPDE#TRPBF
726 ₽
Рутоника
LT3091MPDE#TRPBF
760 ₽
LT3091MPDE#PBF
от 1 976 ₽
LT3091
IN Pin Voltage (Note 3) SET Pin Voltage with Respect to GND Pin ...0.3V, –40V with Respect to IN Pin (Note 3) ...–0.3V, 36V ILIM Pin Voltage with Respect to GND Pin ..±36V with Respect to IN Pin (Note 3) ..–0.3V, 0.7V SET Pin Current (Note 9)..±5mA IMONP Pin Voltage OUT Pin Voltage with Respect to IN Pin (Note 3) ...–0.3V, 40V with Respect to IN Pin (Note 3) ...–0.3V, 36V with Respect to GND Pin ..–40V, 20V with Respect to GND Pin ..±36V with Respect to IMONN Pin ..–40V, 20V Output Short-Circuit Duration .. Indefinite IMONN Pin Voltage Operating Junction Temperature Range (Note 2) with Respect to IN Pin (Note 3) ...–0.3V, 40V E-, I-Grade .. –40°C to 125°C with Respect to GND Pin ..–40V, 20V MP-Grade ... –55°C to 150°C SHDN Pin Voltage H-Grade .. –40°C to 150°C with Respect to IN Pin (Note 3) ...–0.3V, 55V Storage Temperature Range .. –65°C to 150°C with Respect to GND Pin ..–40V, 20V Lead Temperature (Soldering, 10 Sec) FE, R, T7 Packages ..300°C
pin conFiguraTion
TOP VIEW TOP VIEW IN 1 16 OUT IN 1 14 OUT IN 2 15 OUT IN 2 13 OUT IN 3 14 OUT IN 3 12 OUT IN 4 17 13 OUT IN 15 4 11 OUT IN ILIM 5 IN 12 GND ILIM 5 10 GND IMONP 6 9 SET IMONP 6 11 SET IMONN 7 8 SHDN IMONN 7 10 SHDN NC 8 9 NC DE PACKAGE 14-LEAD (4mm × 3mm) PLASTIC DFN FE PACKAGE T 16-LEAD PLASTIC TSSOP JMAX = 150°C, θJA = 27°C/W, θJC = 5.5°C/W EXPOSED PAD (PIN 15) IS IN, MUST BE SOLDERED TO PCB TJMAX = 150°C, θJA = 25°C/W, θJC = 8°C/W EXPOSED PAD (PIN 17) IS IN, MUST BE SOLDERED TO PCB FRONT VIEW FRONT VIEW 7 OUT 7 OUT 6 GND 6 GND TAB 5 SET 5 SET TAB IS IN 4 IN 4 IN IS IN 3 SHDN 3 SHDN 2 IMONN 2 IMONN 1 ILIM 1 ILIM R PACKAGE T7 PACKAGE 7-LEAD PLASTIC DD 7-LEAD PLASTIC TO-220 TJMAX = 150°C, θJA = 15°C/W, θJC = 3°C/W TJMAX = 150°C, θJA = 34°C/W, θJC = 3°C/W 3091fa 2 For more information www.linear.com/LT3091 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
