Datasheet AD5232 (Analog Devices) - 4
ОписаниеNonvolatile Memory, Dual 256-Position Digital Potentiometer
Страниц / Страница24 / 4 — AD5232. Data Sheet. Parameter. Symbol. Conditions. Min. Typ1. Max. Unit
ВерсияC
Формат / Размер файлаPDF / 881 Кб
AD5232 Data Sheet Parameter Symbol Conditions Min Typ1 Max Unit
14 предложений от 14 поставщиков
Микросхема Цифровой потенциометр , Digital Potentiometer 50KΩ 256POS Non-Volatile Linear/Log 16Pin TSSOP T/R
AD5232BRUZ50-REEL7
224 ₽
AD5232BRUZ50-REEL7
311 ₽
AD5232BRUZ50-REEL7
418 ₽
ЧипСити
AD5232BRUZ50-REEL7
418 ₽
link to page 12 link to page 12 link to page 10 link to page 21 link to page 21 link to page 4 link to page 4 link to page 4 link to page 4
DYNAMIC CHARACTERISTICS5, 9 Bandwidth −3 dB, BW_10kΩ, R = 10 kΩ 500 kHz Total Harmonic Distortion THDw VA = 1 V rms, VB = 0 V, f = 1 kHz, RAB = 10 kΩ 0.022 % VA = 1 V rms, VB = 0 V, f = 1 kHz, RAB = 50 kΩ, 100 kΩ 0.045 % VW Settling Time tS VDD = 5 V, VSS = 0 V, VA = VDD, VB = 0 V, 0.65/3/6 µs VW = 0.50% error band, Code 0x00 to Code 0x80 for RAB = 10 kΩ/50 kΩ/100 kΩ Resistor Noise Voltage eN_WB RWB = 5 kΩ, f= 1 kHz 9 nV/√Hz Crosstalk (CW1/CW2) CT VA = VDD, VB = 0 V, measure VW with −5 nV-sec adjacent VR making full-scale code change Analog Crosstalk (CW1/CW2) CTA VA1 = VDD, VB1 = 0 V, measure VW1 with VW2 = −70 dB 5 V p-p @ f = 10 kHz; Code1 = 0x80; Code2 = 0xFF FLASH/EE MEMORY RELIABILITY Endurance10 100 kCycles Data Retention11 100 Years 1 Typical parameters represent average readings at 25°C and VDD = 5 V. 2 Resistor position nonlinearity (R-INL) error is the deviation from an ideal value measured between the maximum resistance and the minimum resistance wiper positions. R-DNL measures the relative step change from ideal between successive tap positions. Parts are guaranteed monotonic. IW ~ 50 µA @ VDD = 2.7 V and IW ~ 400 µA @ VDD = 5 V for the RAB = 10 kΩ version, IW ~ 50 µA for the RAB = 50 kΩ version, and IW ~ 25 µA for the RAB = 100 kΩ version (see Figure 22). 3 INL and DNL are measured at VW with the RDACx configured as a potentiometer divider similar to a voltage output digital-to-analog converter. VA = VDD and VB = VSS. DNL specification limits of ±1 LSB maximum are guaranteed monotonic operating conditions (see Figure 23). 4 The A, B, and W resistor terminals have no limitations on polarity with respect to each other. Dual supply operation enables ground-referenced bipolar signal adjustment. 5 Guaranteed by design; not subject to production test. 6 Common-mode leakage current is a measure of the dc leakage from any A, B, or W terminal to a common-mode bias level of VDD/2. 7 Transfer (XFR) mode current is not continuous. Current is consumed while the EEMEMx locations are read and transferred to the RDACx register (see Figure 13). 8 PDISS is calculated from (IDD × VDD) + (ISS × VSS). 9 All dynamic characteristics use VDD = +2.5 V and VSS = −2.5 V, unless otherwise noted. 10 Endurance is qualified to 100,000 cycles per JEDEC Std. 22, Method A117 and measured at −40°C, +25°C, and +85°C. Typical endurance at +25°C is 700,000 cycles. 11 The retention lifetime equivalent at junction temperature (TJ) = 55°C, as per JEDEC Std. 22, Method A117. Retention lifetime, based on an activation energy of 0.6 eV, derates with junction temperature as shown in Figure 44 in the Flash/EEMEM Reliability section. The AD5232 contains 9,646 transistors. Die size = 69 mil × 115 mil, 7,993 sq. mil. Rev. C | Page 4 of 24 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Characteristics—10 kΩ, 50 kΩ, 100 kΩ Versions Interface Timing Characteristics Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Theory of Operation Scratch Pad and EEMEM Programming Basic Operation EEMEM Protection Digital Input/Output Configuration Serial Data Interface Daisy-Chaining Operation Advanced Control Modes Increment and Decrement Commands Logarithmic Taper Mode Adjustment Using Additional Internal, Nonvolatile EEMEM Terminal Voltage Operating Range Detailed Potentiometer Operation Programming the Variable Resistor Rheostat Operation Programming the Potentiometer Divider Voltage Output Operation Operation from Dual Supplies Application Programming Examples Equipment Customer Start-up Sequence for a PCB Calibrated Unit with Protected Settings Flash/EEMEM Reliability Evaluation Board Outline Dimensions Ordering Guide
