Datasheet TCR8BM (Toshiba) - 7
| Производитель | Toshiba |
| Описание | Low Dropout (LDO) Linear Voltage Regulator |
| Страниц / Страница | 11 / 7 — TCR8BM series. Application Note. 1. Example of Application Circuit. … |
| Формат / Размер файла | PDF / 722 Кб |
TCR8BM series. Application Note. 1. Example of Application Circuit. VBIAS. CONTROL. Output. voltage. HIGH. ON/OFF. 0.1 μF. LOW. OFF. GND. OPEN. VIN
TCR8BM series
Application Note 1. Example of Application Circuit VBIAS CONTROL Output voltage voltage VBIAS HIGH ON ON/OFF CONTROL 0.1 μF LOW OFF GND OPEN OFF VIN VOUT 1.0 μF CL RL LOAD 2.2 μF
The figure above shows the Example of configuration for using a Low dropout regulator. Insert a capacitor at VIN, VOUT and VBIAS pins for stable input/output operation. (Ceramic capacitors can be used).
2. Power Dissipation
Board-mounted power dissipation ratings for TCR8BM series are available in the Absolute Maximum Ratings table. Power dissipation is measured on the board condition shown in below. [The Board Condition] Board material: Glass epoxy (FR4) Board dimension: 40 mm x 40 mm (4layer),t = 1.8 mm Metal pattern ratio: approximately 70% each layer © 2018-2019 7 2019-01-15 Toshiba Electronic Devices & Storage Corporation
