Datasheet HVLED001B (STMicroelectronics) - 10
| Производитель | STMicroelectronics |
| Описание | DS12748: High power factor flyback controller with constant voltage primary-sensing and ultra-low standby consumption |
| Страниц / Страница | 33 / 10 — Electrical characteristics. HVLED001B. Table 6. Electrical … |
| Версия | 1.0 |
| Формат / Размер файла | PDF / 1.0 Мб |
Electrical characteristics. HVLED001B. Table 6. Electrical characteristics. Symbol. Pin. Parameter. Test condition. Min. Typ. Max. Unit
28 предложений от 14 поставщиков HIGH VOLTAGE LED DRIVER. LED Driver IC 1 Output AC DC Offline Switcher Flyback, SEPIC, Step-Down (Buck), Step-Up (Boost) PWM Dimming... |
| HVLED001BTR STMicroelectronics | от 27 ₽ | |
| HVLED001BTR STMicroelectronics | 175 ₽ | |
| HVLED001BTR STMicroelectronics | по запросу | |
link to page 13 link to page 13 link to page 13
Electrical characteristics HVLED001B 5 Electrical characteristics
(Tj = -40 °C to 125 °C, 25 °C production tested, VCC = 15 V, unless otherwise specified.)
Table 6. Electrical characteristics Symbol Pin Parameter Test condition Min. Typ. Max. Unit Supply voltage
Vcc,on VCC Turn-on threshold (1) 11.9 13.2 14.6 V Low consumption mode Low consumption mode(1) 7.3 7.9 8.5 V Vcc,su VCC activation Startup 1.3 1.5 1.7 V Vcc,shd VCC VCC for IC reset Low consumption(1) 6.3 6.84 7.4 V
Supply current
Istartup VCC Start-up current Startup, Vcc < Vcc,on - 125 160 A Operating supply No switching(2) - 2 3 mA ICC VCC current See relevant graph - Low consumption mode, Iq VCC Quiescent current - 480 600 A OPTO = 0 V
High voltage start-up generator
VHV HVSU Breakdown voltage IHV < 100 A 800 - - V VHVstart HVSU Start voltage IVcc < 100 A 40 46 55 V Icharge,su VCC Initial charging current VHVSU > VHvstart, Vcc < 1 V 0.3 0.56 0.7 mA VHVSU > VHvstart, Icharge VCC VCC charge current 2 3.4 4 mA Startup, VCC < Vcc,on VHVSU > VHvstart, Vcc < 1 V 0.3 0.65 1.1 IHV, ON HVSU ON-state current mA VHVSU > VHvstart, Startup, 2.3 4 5 Vcc < Vcc,on OFF-state leakage IHV, OFF HVSU VHVSU = 400 V, Active mode - 18 30 A current
Input voltage sensing
Surge protection Vsurge HVSU 500 570 620 V threshold
Feedback input
FB voltage for minimum VFB,os FB Active mode(3) (4) 0.9 1 1.12 V VCS Active mode, VFBint = 2.0 V, kp FB Multiplier gain VHVSU = 300 V(4) 0.32 0.4 0.48 - Active mode, IFBsrc FB FB pin pull-up current VZCD,off = 2.0 V, 0.7 1 1.3 mA VFB = 1.65 V 10/33 DS12748 Rev 1 Document Outline Table 1. Device summary 1 Block diagram Figure 1. Block diagram 2 Typical application - HPF flyback Figure 2. Primary side regulated (PSR) application Figure 3. Secondary side regulated (SSR) application 3 Pin settings Figure 4. Pin connection Table 2. Pin description (continued) 4 Electrical data 4.1 Absolute maximum ratings Table 3. Absolute maximum ratings 4.2 Thermal data Table 4. Thermal data 4.3 Recommended operating conditions Table 5. Recommended operating conditions 5 Electrical characteristics Table 6. Electrical characteristics (continued) 6 Typical electrical characteristic 6.1 Parameter graphs Figure 5. ICC vs. Fsw @ VCC = 15V Figure 6. VCC,on and VCC,su vs. Tj Figure 7. Icharge and Icharge,su vs. Tj Figure 8. IFB,src and IFB,snk vs. Tj Figure 9. Vbm, Vbm2 and VOPTO,dis vs. Tj Figure 10. Tbm and Tbm2 vs. Tj Figure 11. VZCD,arm and VZCD,trig vs. Tj Figure 12. VCS,lim vs. Tj Figure 13. VREF,PSR vs. Tj Figure 14. IFB vs. VZCD sample Figure 15. TBLANK,min vs. Tj Figure 16. TBLANK,var vs. Tj 7 Application information 7.1 Operating modes Figure 17. High power factor flyback - Primary side regulated constant output voltage Figure 18. High power factor flyback – Secondary side regulated application 7.1.1 Start-up mode Figure 19. Initial start-up phase 7.1.2 Ramp-up mode 7.1.3 Active mode 7.1.4 Low consumption mode 7.1.5 Stop mode 7.2 Control loop Figure 20. Control loop blocks 7.2.1 Current sense input 7.2.2 Feedback input 7.2.3 Zero current detection Figure 21. TBLANK,var time vs. TOFF voltage Figure 22. TBLANK,var time vs. TOFF voltage 7.2.4 Primary side regulation feature Figure 23. PSR E/A small signal model 7.2.5 Burst mode operation 7.3 Gate driver 7.4 IC supply management 7.4.1 VCC supply management 7.4.2 High voltage startup Table 7. HVSU operating modes 7.5 Auto restart timer (ART) 7.6 Protections 7.6.1 Over current protection (OCP) 7.6.2 Input over voltage protection (I-OVP) 7.6.3 Brownout protection (BO) 7.6.4 Over power protection (OPP) 7.6.5 Output over voltage protection (oOVP) 7.7 Disable and monitor feature 8 Package information 8.1 SSOP10 package outline Figure 24. SSOP10 package mechanical data Table 8. SSOP10 package mechanical data 9 Revision history Table 9. Document history
