Datasheet MTD20P06HDL (ON Semiconductor) - 2
ПроизводительON Semiconductor
ОписаниеPower MOSFET 60 V, 20 A, Logic Level, P-Channel DPAK
Страниц / Страница8 / 2 — MTD20P06HDL. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Min. …
Версия6
Формат / Размер файлаPDF / 88 Кб
MTD20P06HDL. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Min. Typ. Max. Unit. OFF CHARACTERISTICS. ON CHARACTERISTICS
MTD20P06HDL ELECTRICAL CHARACTERISTICS Characteristic Symbol Min Typ Max Unit OFF CHARACTERISTICS ON CHARACTERISTICS
TMOS POWER FET LOGIC LEVEL 15 AMPERES 60 VOLTS RDS(on) = 175 MOHM
MTD20P06HDL
11 ₽
MTD20P06HDL
28 ₽
MTD20P06HDL
Motorola
MTD20P06HDL
link to page 2 link to page 2
(TJ = 25°C unless otherwise noted)
Drain−Source Breakdown Voltage V(BR)DSS Vdc (VGS = 0 Vdc, ID = 250 mAdc) 60 − − Temperature Coefficient (Positive) − 81.3 − mV/°C Zero Gate Voltage Drain Current IDSS mAdc (VDS = 60 Vdc, VGS = 0 Vdc) − − 1.0 (VDS = 60 Vdc, VGS = 0 Vdc, TJ = 125°C) − − 10 Gate−Body Leakage Current (VGS = ±15 Vdc, VDS = 0) IGSS − − 100 nAdc
ON CHARACTERISTICS
(Note 3) Gate Threshold Voltage VGS(th) Vdc (VDS = VGS, ID = 250 mAdc) 1.0 1.7 2.0 Temperature Coefficient (Negative) − 3.9 − mV/°C Static Drain−Source On−Resistance RDS(on) − 143 175 mW (VGS = 5.0 Vdc, ID = 7.5 Adc) Drain−Source On−Voltage (VGS = 5.0 Vdc) VDS(on) Vdc (ID = 15 Adc) − 2.3 3.0 (ID = 7.5 Adc, TJ = 125°C) − 1.6 2.0 Forward Transconductance (VDS = 10 Vdc, ID = 7.5 Adc) gFS 9.0 11 − mhos
DYNAMIC CHARACTERISTICS
Input Capacitance Ciss − 850 1190 pF Output Capacitance (VDS = 25 Vdc, VGS = 0 Vdc, f = 1.0 MHz) Coss − 210 290 Reverse Transfer Capacitance Crss − 66 130
SWITCHING CHARACTERISTICS
(Note 4) Turn−On Delay Time td(on) − 19 38 ns Rise Time t (V r − 175 350 DS = 30 Vdc, ID = 15 Adc, V Turn−Off Delay Time GS = 5.0 Vdc,RG = 9.1 W) td(off) − 41 82 Fall Time tf − 68 136 Gate Charge QT − 20.6 29 nC Q (V 1 − 3.7 − DS = 48 Vdc, ID = 15 Adc, VGS = 5.0 Vdc) Q2 − 7.6 − Q3 − 8.4 −
SOURCE−DRAIN DIODE CHARACTERISTICS
Forward On−Voltage V Vdc (I SD S = 15 Adc, VGS = 0 Vdc) − 2.5 3.0 (IS = 15 Adc, VGS = 0 Vdc, TJ = 125°C) − 1.9 − Reverse Recovery Time trr − 64 − ns t (I a − 50 − S = 15 Adc, VGS = 0 Vdc, dIS/dt = 100 A/ms) tb − 14 − Reverse Recovery Stored Charge QRR − 0.177 − mC
INTERNAL PACKAGE INDUCTANCE
Internal Drain Inductance LD − 4.5 − nH (Measured from the drain lead 0.25″ from package to center of die) Internal Source Inductance LS − 7.5 − nH (Measured from the source lead 0.25″ from package to source bond pad) 3. Pulse Test: Pulse Width ≤ 300 ms, Duty Cycle ≤ 2%. 4. Switching characteristics are independent of operating junction temperature.
http://onsemi.com 2
