Datasheet AS6500 (AustriaMicroSystems) - 6
ПроизводительAustriaMicroSystems
ОписаниеTime-to-Digital Converter 4-channel TDC with CMOS inputs
Страниц / Страница56 / 6 — Pin Assignment. Figure 3: AS6500 QFN40. Figure 4: Pin Description of …
Версия3-00
Формат / Размер файлаPDF / 1.9 Мб
Pin Assignment. Figure 3: AS6500 QFN40. Figure 4: Pin Description of AS6500 QFN40. Pin. Not. Pin Name. Pin Type. Description. Number
Pin Assignment Figure 3: AS6500 QFN40 Figure 4: Pin Description of AS6500 QFN40 Pin Not Pin Name Pin Type Description Number
25 предложений от 8 поставщиков
Микросхема: AS6500-FQFM QFN40 LF T&RDP
Зенер
Россия и страны ТС
AS6500-FQFM
от 1 407 ₽
Эиком
AS6500-FQFM
ScioSense
от 3 309 ₽
Элитан
AS6500-FQFM
3 319 ₽
Hi-Tech Circuit Group
AS6500-FQFM
ScioSense
Document Feedback AS6500 Pin Assignment
3 Pin Assignment
3.1 Pin Diagram
IN R T R D E E R F E T V D O F V D M M R O D G S SSN U S D I O D N S C P C S 33 S D O K O C 18 T I I 40 31 30 1 TGND NC STOP1 DVDD33 STOP2 NC TVDD33 TSTO RSTIDX TSTO AS6500 REFCLK TSTO DISABLE TSTO TGND NC STOP3 TSTO 10 21 11 20 STOP4 NC D D D R V R C C T T G V V V D G G V V V N D D D D N N D D D D D D D 18 D D D D D 33 18 33 18 18 33 O 3.2 Pin Description
Figure 4: Pin Description of AS6500 QFN40 Pin Not Pin Name Pin Type Description Number Used
1 NC Not connected 2 DVDD33 Power Supply 3.3V supply for digital and IO units 3 NC Not connected Datasheet • PUBLIC DS000640 • v3-00 • 2019-Feb-21 56 │ 6 Document Outline Content Guide 1 General Description 1.1 Key Benefits & Features 1.2 Applications 1.3 Block Diagram 2 Ordering Information 3 Pin Assignment 3.1 Pin Diagram 3.2 Pin Description 4 Absolute Maximum Ratings 5 Recommended Operation Conditions 6 Typical Characteristics 6.1 Converter Characteristics 6.2 Power Supply Characteristics 6.3 Reference Clock and Stop Input Requirements 6.4 Serial Communication Interface 6.5 Typical Operating Characteristics 7 Register Description 7.1 Register Overview 7.2 Detailed Register Description 7.2.1 CFG0 Register (Address 0) 7.2.2 CFG1 Register (Address 1) 7.2.3 CFG2 Register (Address 2) 7.2.4 CFG3, CFG4, CFG5 Registers (Addresses 3 to 5) 7.2.5 CFG6 Register (Address 6) 7.2.6 CFG7 Register (Address 7) 7.2.7 CFG8 to CFG15 Register (Addresses 8 to 15) 7.2.8 CFG16 Register (Address 16) 7.2.9 CHANNEL1 Result Register (Addresses 8 to 13) 7.2.10 CHANNEL2 Result Register (Addresses 14 to 19) 7.2.11 CHANNEL3 Result Register (Addresses 20 to 25) 7.2.12 CHANNEL4 Result Register (Addresses 26 to 31) 8 Detailed Description 8.1 Time Measurements and Results 8.1.1 Measurements of AS6500 8.1.2 Output Results 8.1.3 Calculation of Time Differences GENERAL APPROACH 8.2 Resolution 8.2.1 RMS-Resolution versus Effective Resolution 8.2.2 High Resolution 8.3 Combining Two Stop Channels 8.3.1 Channel Combination for Low Pulse-to-Pulse Spacing 8.3.2 Channel Combination for Pulse Width Measurement 8.4 Input Pins for Time Measurement 8.4.1 REFCLK: Reference Clock Input 8.4.2 RSTIDX: Reference Index Counter Reset 8.4.3 STOP1 to STOP4: Stop Channels 8.4.4 DISABLE: Stop Disable SOFTWARE ENABLE (HIT_ENA_STOP1…4) PIN ENABLE (PIN_ENA_XXX) 8.5 SPI Communication Interface 8.5.1 General 8.5.2 Detailed Pin Description 8.5.3 Communication Commands (Opcodes) 8.5.4 Data Readout via SPI Interface 8.6 Coding of Results 8.6.1 Configuration of LSB by REFCLK_DIVISIONS 8.6.2 Examples for Codes of Time Measurements Results 8.6.3 Maximum Time Differences 8.7 Conversion Latency and Conversion Rate Converter Latency 8.8 Conversion Rate 8.8.1 Peak Conversion Rate 8.8.2 Read-Out Rate 8.8.3 Average Conversion Rate 8.8.4 FIFOs for Adapting Peak and Average Conversion Rate 9 Application Information 9.1 Configuration Examples 9.2 Example C++ Code 9.3 Schematic 9.4 External Components 10 Package Drawings & Markings 11 Reel Information 12 Soldering & Storage Information 13 Revision Information 14 Legal Information
