Datasheet VLDB1232, VLDTG1232 (Vishay) - 2
ПроизводительVishay
ОписаниеDome Lens SMD LED
Страниц / Страница10 / 2 — VLDB1232.., VLDTG1232.. ABSOLUTE MAXIMUM RATINGS. VLDB1232..., …
Версия1.0
Формат / Размер файлаPDF / 238 Кб
VLDB1232.., VLDTG1232.. ABSOLUTE MAXIMUM RATINGS. VLDB1232..., VLDTG1232... PARAMETER. TEST CONDITION. SYMBOL. VALUE. UNIT. Note
VLDB1232.., VLDTG1232. ABSOLUTE MAXIMUM RATINGS VLDB1232..., VLDTG1232.. PARAMETER TEST CONDITION SYMBOL VALUE UNIT Note
32 предложений от 10 поставщиков
Светодиод, Синий, SMD (Поверхностный Монтаж), 2.3mm x 2.3mm, 20 мА, 3 В, 465 нм
VLDB1232R-08
19 ₽
VLDB1232R-08
34 ₽
Эиком
VLDB1232R-08
от 47 ₽
VLDB1232R-08
49 ₽
www.vishay.com Vishay Semiconductors
(Tamb = 25 °C, unless otherwise specified)
VLDB1232..., VLDTG1232... PARAMETER TEST CONDITION SYMBOL VALUE UNIT
Reverse voltage (1) Short term application only VR 5 V DC Forward current Tamb ≤ 60 °C IF 30 mA Power dissipation PV 100 mW Junction temperature Tj 100 °C Operating temperature range Tamb -40 to +100 °C Storage temperature range Tstg -40 to +100 °C Thermal resistance junction-to-ambient Mounted on PC board (pad size > 16 mm2) RthJA 400 K/W
Note
(1) Driving the LED in reverse direction is suitable for a short term application only
OPTICAL AND ELECTRICAL CHARACTERISTICS
VLDB1232G.., VLDB1232R.., BLUE PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Luminous intensity (1) IF = 20 mA IV 1800 3500 - mcd Luminous flux/luminous intensity φV/IV - 0.35 - mlm/mcd Dominant wavelength (1) IF = 20 mA λd 458 465 472 nm Radiant intensity IF = 20 mA Ie - 62 - mW/sr Peak wavelength IF = 20 mA λp - 460 - nm Spectral bandwidth at 50 % Irel max. IF = 20 mA Δλ - 18 - nm Angle of half intensity IF = 20 mA ϕ - ± 9 - ° Forward voltage (1) IF = 20 mA VF 2.6 3.0 3.4 V Reverse current VR = 5 V IR - 0.01 10 μA
Note
(1) Tolerances: ± 15 % for IV, ± 0.1 V for VF, ± 1 nm for λd
VLDTG1232G.., VLDTG1232R.., TRUE GREEN PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Luminous intensity (1) IF = 20 mA IV 7100 16 000 - mcd Luminous flux/luminous intensity φV/IV - 0.35 - mlm/mcd Dominant wavelength (1) IF = 20 mA λd 515 525 541 nm Radiant intensity IF = 20 mA Ie - 37 - mW/sr Peak wavelength IF = 20 mA λp - 519 - nm Spectral bandwidth at 50 % Irel max. IF = 20 mA Δλ - 28 - nm Angle of half intensity IF = 20 mA ϕ - ± 9 - ° Forward voltage (1) IF = 20 mA VF 2.6 2.9 3.4 V Reverse current VR = 5 V IR - 0.01 10 μA
Note
(1) Tolerances: ± 15 % for IV, ± 0.1 V for VF, ± 1 nm for λd Rev. 1.0, 12-Feb-2019
2
Document Number: 80003 For technical questions, contact: LED@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
