Datasheet ADL5545 (Analog Devices) - 3
Описание30 MHz to 6 GHz RF/IF Gain Block
Страниц / Страница20 / 3 — Data Sheet. ADL5545. SPECIFICATIONS. Table 1. Parameter. Test …
ВерсияA
Формат / Размер файлаPDF / 385 Кб
Data Sheet. ADL5545. SPECIFICATIONS. Table 1. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet ADL5545 SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
VPOS = 5 V and TA = 25°C, unless otherwise noted.
OVERALL FUNCTION Frequency Range 30 6000 MHz FREQUENCY = 30 MHz Gain 22.6 dB Output 1 dB Compression Point 12.0 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 30.3 dBm Noise Figure 3.8 dB FREQUENCY = 140 MHz Gain 24.8 dB vs. Frequency ±10 MHz ±0.03 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.6 dB vs. Supply 4.75 V to 5.25 V ±0.30 dB Output 1 dB Compression Point 14.6 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 31.5 dBm Noise Figure 3.1 dB FREQUENCY = 350 MHz Gain 24.6 dB vs. Frequency ±10 MHz ±0.01 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.6 dB vs. Supply 4.75 V to 5.25 V ±0.30 dB Output 1 dB Compression Point 16.1 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 32.6 dBm Noise Figure 3.3 dB FREQUENCY = 700 MHz Gain 23.7 24.4 25.1 dB vs. Frequency ±50 MHz ±0.05 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.5 dB vs. Supply 4.75 V to 5.25 V ±0.13 dB Output 1 dB Compression Point 17.9 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 38.8 dBm Noise Figure 3.0 dB FREQUENCY = 900 MHz Gain 23.4 24.1 24.8 dB vs. Frequency ±50 MHz ±0.07 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.5 dB vs. Supply 4.75 V to 5.25 V ±0.13 dB Output 1 dB Compression Point 18.1 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 36.4 dBm Noise Figure 2.9 dB FREQUENCY = 1900 MHz Gain 21.5 22.2 22.9 dB vs. Frequency ±50 MHz ±0.11 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.7 dB vs. Supply 4.75 V to 5.25 V ±0.17 dB Output 1 dB Compression Point 16.6 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 35.2 dBm Noise Figure 3.4 dB Rev. A | Page 3 of 20 Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 500 MHz to 4 GHz Frequency Band 100 MHz to 500 MHz Frequency Band 4 GHz to 6 GHz Frequency Band General Applications Information Basic Connections Soldering Information and Recommended PCB Land Pattern Operation Down to 30 MHz W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
