Datasheet ADL5544 (Analog Devices) - 4
Описание30 MHz to 6 GHz RF/IF Gain Block
Страниц / Страница20 / 4 — ADL5544. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. …
ВерсияA
Формат / Размер файлаPDF / 393 Кб
ADL5544. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
ADL5544 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
28 предложений от 15 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
Microfind
ADL5544ARKZ-R7
205 ₽
ADL5544ARKZ-R7
Maxim
205 ₽
ADL5544ARKZ-R7
ADL5544ARKZ-R7
FREQUENCY = 2140 MHz Gain 15.9 16.4 16.7 dB vs. Frequency ±50 MHz ±0.04 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.4 dB vs. Supply 4.75 V to 5.25 V ±0.05 dB Output 1 dB Compression Point 14.8 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −7 dBm per tone 31.3 dBm Noise Figure 3.5 dB FREQUENCY = 2600 MHz Gain 15.6 16.0 16.4 dB vs. Frequency ±50 MHz ±0.03 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.3 dB vs. Supply 4.75 V to 5.25 V ±0.05 dB Output 1 dB Compression Point 14.1 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −7 dBm per tone 30.0 dBm Noise Figure 3.7 dB FREQUENCY = 3500 MHz Gain 15.2 15.6 16.1 dB vs. Frequency ±50 MHz ±0.05 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.4 dB vs. Supply 4.75 V to 5.25 V ±0.03 dB Output 1 dB Compression Point 12.2 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −7 dBm per tone 26.0 dBm Noise Figure 4.1 dB FREQUENCY = 4000 MHz Gain 14.4 15.0 15.5 dB vs. Frequency ±50 MHz ±0.10 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.6 dB vs. Supply 4.75 V to 5.25 V ±0.08 dB Output 1 dB Compression Point 10.8 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −7 dBm per tone 23.8 dBm Noise Figure 4.6 dB FREQUENCY = 5000 MHz Gain 14.0 dB vs. Frequency ±50 MHz ±0.04 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.6 dB vs. Supply 4.75 V to 5.25 V ±0.10 dB Output 1 dB Compression Point 8.7 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −7 dBm per tone 21.3 dBm Noise Figure 4.8 dB FREQUENCY = 5800 MHz Gain 14.5 dB vs. Frequency ±50 MHz ±0.15 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±1.0 dB vs. Supply 4.75 V to 5.25 V ±0.10 dB Output 1 dB Compression Point 7.0 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −7 dBm per tone 18.7 dBm Noise Figure 5.4 dB POWER INTERFACE VPOS Supply Voltage 4.75 5 5.25 V Supply Current 55 69 mA vs. Temperature −40°C ≤ TA ≤ +85°C −5 mA Power Dissipation VPOS = 5 V 275 mW Rev. A | Page 4 of 20 Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 500 MHz to 4 GHz Frequency Band 100 MHz to 500 MHz Frequency Band 4 GHz to 6 GHz Frequency Band General Applications Information Basic Connections Soldering Information and Recommended PCB Land Pattern Operation Down to 30 MHz W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
