Datasheet HMC405 (Analog Devices) - 5
ОписаниеInGaP HBT GAIN BLOCK MMIC AMPLIFIER, DC - 10 GHz
Страниц / Страница6 / 5 — HMC405. InGaP HBT GAIN BLOCK. MMIC AMPLIFIER, DC - 10 GHz. Pad …
Формат / Размер файлаPDF / 286 Кб
HMC405. InGaP HBT GAIN BLOCK. MMIC AMPLIFIER, DC - 10 GHz. Pad Descriptions. Application Circuit. Recommended Component Values
HMC405 InGaP HBT GAIN BLOCK MMIC AMPLIFIER, DC - 10 GHz Pad Descriptions Application Circuit Recommended Component Values
24 предложений от 18 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
HMC405
Hittite
1 489 ₽
HMC405
ТаймЧипс
HMC405_09
Hittite
HMC405
Hittite
HMC405
v03.0109
2 Pad Number Function Description Interface Schematic This pin is DC coupled. IP 1 RFIN An off chip DC blocking capacitor is required. H - C S 2 RFOUT RF output and DC Bias for the output stage. R IE Die GND Die bottom must be connected to RF/DC ground. IF Bottom L P M
Application Circuit
K A OC BL Note: 1. Select Rbias to achieve Icq using equation below, IN Rbias > 22 Ohm. A 2. External blocking capacitors are required on RFIN and RFOUT. Icq = Vs - 3.9 & G Rbias R E IV R D
Frequency (MHz) Component 50 1000 3000 7000 L1 270 nH 56 nH 8.2 nH 2.2 nH C1, C2 0.01 μF 100 pF 100 pF 100 pF Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
2 - 24
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
