Datasheet AD8353 (Analog Devices) - 3
Описание1 MHz TO 2.7 GHz RF Gain Block
Страниц / Страница16 / 3 — Data Sheet. AD8353. SPECIFICATIONS. Table 1. Parameter. Test …
ВерсияF
Формат / Размер файлаPDF / 347 Кб
Data Sheet. AD8353. SPECIFICATIONS. Table 1. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD8353 SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
51 предложений от 21 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
AD8353ACPZ-REEL7
88 ₽
Элрус
AD8353ACPZ-REEL7
от 133 ₽
Зенер
Россия и страны ТС
AD8353ACPZ-REEL7
от 198 ₽
Эиком
AD8353ACPZ-REEL7
от 271 ₽
VS = 3 V, TA = 25°C, 100 nH external inductor between RFOUT and VPOS, ZO = 50 Ω, unless otherwise noted.
OVERALL FUNCTION Frequency Range 1 2700 MHz Gain f = 900 MHz 19.8 dB f = 1.9 GHz 17.7 dB f = 2.7 GHz 15.6 dB Delta Gain f = 900 MHz, −40°C ≤ TA ≤ +85°C −0.97 dB f = 1.9 GHz, −40°C ≤ TA ≤ +85°C −1.15 dB f = 2.7 GHz, −40°C ≤ TA ≤ +85°C −1.34 dB Gain Supply Sensitivity VPOS ± 10%, f = 900 MHz 0.04 dB/V f = 1.9 GHz −0.004 dB/V f = 2.7 GHz −0.04 dB/V Reverse Isolation (S12) f = 900 MHz −35.6 dB f = 1.9 GHz −34.9 dB f = 2.7 GHz −30.3 dB RF INPUT INTERFACE Pin RFIN Input Return Loss f = 900 MHz 22.3 dB f = 1.9 GHz 20.9 dB f = 2.7 GHz 11.2 dB RF OUTPUT INTERFACE Pin RFOUT Output Compression Point f = 900 MHz, 1 dB compression 9.1 dBm f = 1.9 GHz 8.4 dBm f = 2.7 GHz 7.6 dBm Delta Compression Point f = 900 MHz, −40°C ≤ TA ≤ +85°C −1.46 dB f = 1.9 GHz, −40°C ≤ TA ≤ +85°C −1.17 dB f = 2.7 GHz, −40°C ≤ TA ≤ +85°C −1 dB Output Return Loss f = 900 MHz 26.3 dB f = 1.9 GHz 16.9 dB f = 2.7 GHz 13.3 dB DISTORTION/NOISE Output Third-Order Intercept f = 900 MHz, ∆f = 1 MHz, PIN = −28 dBm 23.6 dBm f = 1.9 GHz, ∆f = 1 MHz, PIN = −28 dBm 20.8 dBm f = 2.7 GHz, ∆f = 1 MHz, PIN = −28 dBm 19.5 dBm Output Second-Order Intercept f = 900 MHz, ∆f = 1 MHz, PIN = −28 dBm 31.6 dBm Noise Figure f = 900 MHz 5.3 dB f = 1.9 GHz 6 dB f = 2.7 GHz 6.8 dB POWER INTERFACE Pin VPOS Supply Voltage 2.7 3 3.3 V Total Supply Current 35 41 48 mA Supply Voltage Sensitivity 15.3 mA/V Temperature Sensitivity −40°C ≤ TA ≤ +85°C 60 µA/°C Rev. F | Page 3 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC CONNECTIONS APPLICATIONS INFORMATION LOW FREQUENCY APPLICATIONS BELOW 100 MHz EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
