Datasheet HMC395 (Analog Devices) - 5
ОписаниеInGaP HBT GAIN BLOCK MMIC AMPLIFIER, DC - 4 GHz
Страниц / Страница6 / 5 — HMC395. InGaP HBT GAIN BLOCK. MMIC AMPLIFIER, DC - 4 GHz. Pad …
Формат / Размер файлаPDF / 274 Кб
HMC395. InGaP HBT GAIN BLOCK. MMIC AMPLIFIER, DC - 4 GHz. Pad Descriptions. Application Circuit. Recommended Component Values
HMC395 InGaP HBT GAIN BLOCK MMIC AMPLIFIER, DC - 4 GHz Pad Descriptions Application Circuit Recommended Component Values
13 предложений от 10 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ усилители
Зенер
Россия и страны ТС
HMC395-SX
от 6 305 ₽
ЧипСити
HMC395-SX
7 629 ₽
Эиком
HMC395-SX
от 14 886 ₽
HMC395-SX
HMC395
V02.0109
2 Pad Number Function Description Interface Schematic This pin is DC coupled. IP 1 RFIN An off chip DC blocking capacitor is required. H - C S 2 RFOUT RF output and DC Bias for the output stage. R IE Die GND Die bottom must be connected to RF/DC ground. IF Bottom L P M
Application Circuit
K A OC BL Note: IN 1. Select Rbias to achieve Icq using equation below, A Rbias > 22 Ohm. 2. External blocking capacitors are required on RFIN and RFOUT. & G Icq = Vs - 3.9 R Rbias E IV R D
Frequency (MHz) Component 50 100 500 1000 4000 L1 270 nH 270 nH 100 nH 56 nH 8.2 nH C1, C2 0.01 μF 0.01 μF 500 pF 100 pF 100 pF Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
2 - 6
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
