Datasheet EFR32BG21 (Silicon Labs) - 10
ПроизводительSilicon Labs
ОписаниеBlue Gecko Wireless SoCFamily
Страниц / Страница72 / 10 — 3.7 Security Features. 3.7.1 Standard Security. 3.7.2 True Random Number …
Формат / Размер файлаPDF / 941 Кб
3.7 Security Features. 3.7.1 Standard Security. 3.7.2 True Random Number Generator. 3.8 Analog. 3.8.1 Analog Comparator (ACMP)
3.7 Security Features 3.7.1 Standard Security 3.7.2 True Random Number Generator 3.8 Analog 3.8.1 Analog Comparator (ACMP)
28 предложений от 9 поставщиков
IC MCU 2.4G 10DB BLUETOOTH 5.1. IC RF 32-VFQFN Exposed Pad. RF Transceiver ICs
EFR32BG21A010F768IM32-B
Silicon Labs
70 ₽
Silicon Labs
178 ₽
Элитан
Silicon Labs
429 ₽
Silicon Labs
от 479 ₽
EFR32BG21 Blue Gecko Wireless SoC Family Data Sheet System Overview
Standard Security includes the following features: • Cryptographic Accelerator with Standard Ciphers • True Random Number Generator The Cryptographic Accelerator is a fast and energy-efficient autonomous hardware accelerator for advanced cryptographic ciphers. The standard security devices support AES encryption and decryption with 128/192/256-bit keys, ECC over both GF(P) and GF(2m), SHA-1 and SHA-2 (SHA-224 and SHA-256). Supported block cipher modes of operation for AES include: ECB, CTR, CBC, PCBC, CFB, OFB, GCM, CBC-MAC, GMAC and CCM. The Cryptographic Accelerator accelerates Elliptical Curve Cryptography and supports the NIST recommended curves including P-192, P-224, P-256, K-163, K-233, B-163 and B-233. The cryptographic accelerator supports ECDH (Elliptic Curve Diffie-Hellman) and ECDSA (Elliptic Curve Digital Signing Algorithm). These functions provide a fast and energy efficient solution for public key cryptography key exchange and digital signatures.
The True Random Number Generator module is a non-deterministic random number generator based on a full hardware solution. It includes start-up and online health tests for the entropy source as required by NIST SP800-90B and AIS-31. The TRNG is suitable for periodically generating entropy to seed an approved pseudo random number generator. The psuedorandom number generator then provides key generation in a secure system.
The Analog Comparator is used to compare the voltage of two analog inputs, with a digital output indicating which input voltage is high- er. Inputs are selected from among internal references and external pins. The tradeoff between response time and current consumption is configurable by software. Two 6-bit reference dividers allow for a wide range of internally-programmable reference sources. The ACMP can also be used to monitor the supply voltage. An interrupt can be generated when the supply falls below or rises above the programmable threshold.
3.8.2 Analog to Digital Converter (ADC)
The ADC is an Intermediate architecture combining techniques from both SAR and Delta-Sigma style converters, It has a resolution of up to 12 bits at up to 1 Msps. Hardware oversampling reduces system-level noise over multiple front-end samples. The ADC includes integrated voltage references. Inputs are selectable from a wide range of sources, including pins configurable as either single-ended or differential.
3.9 Reset Management Unit (RMU)
The RMU is responsible for handling reset of the EFR32BG21. A wide range of reset sources are available, including several power supply monitors, pin reset, software controlled reset, core lockup reset, and watchdog reset.
silabs.com
| Building a more connected world. Rev. 1.0 | 10 Document Outline 1. Feature List 2. Ordering Information 3. System Overview 3.1 Introduction 3.2 Radio 3.2.1 Antenna Interface 3.2.2 Fractional-N Frequency Synthesizer 3.2.3 Receiver Architecture 3.2.4 Transmitter Architecture 3.2.5 Packet and State Trace 3.2.6 Data Buffering 3.2.7 Radio Controller (RAC) 3.3 General Purpose Input/Output (GPIO) 3.4 Clocking 3.4.1 Clock Management Unit (CMU) 3.4.2 Internal and External Oscillators 3.5 Counters/Timers and PWM 3.5.1 Timer/Counter (TIMER) 3.5.2 Low Energy Timer (LETIMER) 3.5.3 Real Time Clock with Capture (RTCC) 3.5.4 Back-Up Real Time Counter 3.5.5 Watchdog Timer (WDOG) 3.6 Communications and Other Digital Peripherals 3.6.1 Universal Synchronous/Asynchronous Receiver/Transmitter (USART) 3.6.2 Inter-Integrated Circuit Interface (I2C) 3.6.3 Peripheral Reflex System (PRS) 3.7 Security Features 3.7.1 Standard Security 3.7.2 True Random Number Generator 3.8 Analog 3.8.1 Analog Comparator (ACMP) 3.8.2 Analog to Digital Converter (ADC) 3.9 Reset Management Unit (RMU) 3.10 Core and Memory 3.10.1 Processor Core 3.10.2 Memory System Controller (MSC) 3.10.3 Linked Direct Memory Access Controller (LDMA) 3.11 Memory Map 3.12 Configuration Summary 4. Electrical Specifications 4.1 Electrical Characteristics 4.1.1 Absolute Maximum Ratings 4.1.2 General Operating Conditions 4.1.3 Thermal Characteristics 4.1.4 Current Consumption 4.1.4.1 MCU current consumption at 1.8V 4.1.4.2 MCU current consumption at 3.0V 4.1.4.3 Radio current consumption at 1.8V 4.1.4.4 Radio current consumption at 3.0V 4.1.5 2.4 GHz RF Transceiver Characteristics 4.1.5.1 RF Transmitter Characteristics 4.1.5.2 RF Receiver Characteristics 4.1.6 Flash Characteristics 4.1.7 Wake Up, Entry, and Exit times 4.1.8 Oscillators 4.1.8.1 High Frequency Crystal Oscillator 4.1.8.2 Low Frequency Crystal Oscillator 4.1.8.3 High Frequency RC Oscillator (HFRCO) 4.1.8.4 Fast Start_Up RC Oscillator (FSRCO) 4.1.8.5 Low Frequency RC Oscillator 4.1.8.6 Ultra Low Frequency RC Oscillator 4.1.9 GPIO Pins (3V GPIO pins) 4.1.10 Analog to Digital Converter (ADC) 4.1.11 Analog Comparator (ACMP) 4.1.12 Temperature Sense 4.1.13 Brown Out Detectors 4.1.13.1 DVDD BOD 4.1.13.2 LE DVDD BOD 4.1.13.3 AVDD and VIO BODs 4.1.14 SPI Electrical Specifications 4.1.14.1 SPI Master Timing 4.1.14.2 SPI Slave Timing 4.1.15 I2C Electrical Specifications 4.1.15.1 I2C Standard-mode (Sm) 4.1.15.2 I2C Fast-mode (Fm) 4.1.15.3 I2C Fast-mode Plus (Fm+) 4.2 Typical Performance Curves 4.2.1 Supply Current 4.2.2 2.4 GHz Radio 5. Typical Connection Diagrams 5.1 Power 5.2 RF Matching Networks 5.2.1 2.4 GHz 0 dBm Matching Network 5.2.2 2.4 GHz 10 dBm Matching Network 5.2.3 2.4 GHz 20 dBm Matching Network 5.3 Other Connections 6. Pin Definitions 6.1 QFN32 2.4GHz Device Pinout 6.2 Alternate Function Table 6.3 Analog Peripheral Connectivity 6.4 Digital Peripheral Connectivity 7. QFN32 Package Specifications 7.1 QFN32 Package Dimensions 7.2 QFN32 PCB Land Pattern 7.3 QFN32 Package Marking 8. Revision History
