Datasheet MAX1932 (Maxim) - 4
ПроизводительMaxim
ОписаниеDigitally Controlled, 0.5% Accurate, Safest APD Bias Supply
Страниц / Страница16 / 4 — Electrical Characteristics (continued). TA = -40°C to +85°C. PARAMETER. …
Формат / Размер файлаPDF / 239 Кб
Electrical Characteristics (continued). TA = -40°C to +85°C. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS
Electrical Characteristics (continued) TA = -40°C to +85°C PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
INTEGRATED CIRCUIT. - Voltage Regulator IC Output. PMIC - Voltage Regulators - Special Purpose
MAX1932ETC/GG8
Hi-Tech Circuit Group
MAX1932ETC/GG8
MAX1932ETC/GG8
Maxim
Рутоника
MAX1932ETC/GG8
Maxim
MAX1932 Digitally Controlled, 0.5% Accurate, Safest APD Bias Supply
(VIN = 3.3V, CS = SCLK = DIN = 3.3V, CS+ = CS- = 45V, Circuit of Figure 2,
TA = -40°C to +85°C
, unless otherwise noted.) (Note 2)
FB Voltage VFB 1.23875 1.26125 V FB to COMP Transconductance COMP = 1.5V 50 200 µS COMP Pulldown Resistance DAC code = 00 hex 100 Ω in Shutdown D AC OU T to FB V ol tag e D i ffer ence DAC code = FF hex -4 +4 mV D AC OU T Differential Nonlinearity DAC Code = 01 to FF hex, DAC -1 +1 LSB (Note 1) guaranteed monotonic DAC code = 0F to FF hex, source or sink D AC OU T Load Regulation -1 +1 mV 50µA Switching Frequency fOSC 240 360 kHz
DIGITAL INPUTS (DIN, SCLK,
CS
Input Low Voltage 0.6 V Input High Voltage 1.4 V
DIGITAL OUTPUT (
CL
Output Low Voltage ISINK = 1mA 0.1 V Output High Voltage ISOURCE = 0.5mA VIN - 0.5 V
SPI TIMING (FIGURE 5)
SCLK Clock Frequency fSCLK 2 MHz SCLK Low Period tCL 125 ns SCLK High Period tCH 125 ns Data Hold Time tDH 0 ns Data Setup Time tDS 125 ns CS Assertion to SCLK tCSS0 200 ns Rising Edge Setup Time CS Deassertion to SCLK tCSS1 200 ns Rising Edge Setup Time SCLK Rising Edge tCSH1 200 ns to CS Deassertion SCLK Rising Edge tCSH0 200 ns to CS Assertion CS High Period tCSW 300 ns
Note 1:
DACOUT = DAC code x (1.25V/256) + 1.25V/256.
Note 2:
Specifications to -40°C are guaranteed by design and not production tested. www.maximintegrated.com Maxim Integrated | 4
