Datasheet XP (IDT) - 9
ПроизводительIDT
Описание150fs Quartz-based PLL Oscillator
Страниц / Страница18 / 9 — Table 16. 1.8V AC Electrical Characteristics. Symbol. Parameter. Test …
Версия20190401
Формат / Размер файлаPDF / 393 Кб
Table 16. 1.8V AC Electrical Characteristics. Symbol. Parameter. Test Condition. Minimum. Typical. Maximum. Units
Table 16 1.8V AC Electrical Characteristics Symbol Parameter Test Condition Minimum Typical Maximum Units
24 предложений от 10 поставщиков
Oscillator, 625MHz, 25ppm, SMD, 7mm x 5mm, 3.3V Supply, LVPECL Out, XP Series
XPP736625.000000I
Renesas
772 ₽
Зенер
Россия и страны ТС
XPP736625.000000I
от 1 370 ₽
Элитан
XPP736625.000000I
Renesas
1 440 ₽
XPP736625.000000I
Renesas
от 1 491 ₽
XP Datasheet
VDD = 1.8V ±5%, TA = -40°C to +85°C, -40°C to +105°C.
LVDS, LVPECL, CML. 15 — 2100 F Output Frequency Range MHz HCSL. 15 — 725 Temperature = -40°C to +85°C. — — ±25 ppm Frequency Stability Temperature = -40°C to +105°C. — — ±50 ppm Frequency Tolerance (25°C) Temperature = 25°C. -15 ±10 +15 ppm Aging (1st year) TA = 25°C. — — ±3 Aging (10 years) TA = 25°C. — — ±10 LVDS. Differential. — 100 — Output Load Ω LVPECL, HCSL. To GND. — 50 — Output valid time after V T DD meets minimum ST Start-up Time — 5 — ms specified level. LVDS. — 311 450 LVPECL. 20% – 80%, — 312 450 tR Output Rise Time ps 156.25MHz HCSL. — 316 450 CML — 313 450 LVDS. — 290 450 LVPECL. 80% – 20%, — 297 450 tF Output Fall Time ps 156.25MHz HCSL. — 294 450 CML — 289 450 LVDS. 156.25MHz 45 — 55 LVPECL. 156.25MHz 45 — 55 ODC Output Clock Duty Cycle % HCSL. 156.25MHz 45 — 55 CML 156.25MHz 45 — 55 TOE Output Enable/Disable Time — — — 1 — ms
Table 17. Phase Jitter Characteristics
VDD = 3.3V, 2.5V, 1.8V ±5%, TA = -40°C to +85°C, -40°C to +105°C.
Symbol Parameter Conditions Minimum Typical Maximum Units
250.00MHz — 115 — fsec 312.50MHz — 125 — fsec fJITTER Phase Jitter (12kHz – 20MHz) 625.00MHz — 123 — fsec 644.53MHz — 120 — fsec ©2019 Integrated Device Technology, Inc. 9 April 1, 2019 Document Outline Description Features Pin Assignments Figure 1. 7.0 × 5.0 mm, 5.0 × 3.2 mm, and 3.2 × 2.5 mm Packages Table 1. Pin Descriptions Absolute Maximum Ratings Table 2. Absolute Maximum Ratings ESD Compliance Table 3. ESD Compliance Mechanical Testing Table 4. Mechanical Testing * Solder Reflow Profile DC Electrical Characteristics Table 5. 3.3V IDD DC Electrical Characteristics Table 6. 2.5V IDD DC Electrical Characteristics Table 7. 1.8V IDD DC Electrical Characteristics Table 8. LVCMOS DC Electrical Characteristics Table 9. LVDS DC Electrical Characteristics Table 10. LVPECL DC Electrical Characteristics Table 11. HCSL DC Electrical Characteristics Table 12. CML DC Electrical Characteristics Table 13. DC Electrical Characteristics – Leakage Current AC Electrical Characteristics Table 14. 3.3V AC Electrical Characteristics Table 15. 2.5V AC Electrical Characteristics Table 16. 1.8V AC Electrical Characteristics Table 17. Phase Jitter Characteristics Output Waveforms Figure 2. LVDS Output Waveforms Figure 3. LVPECL Output Waveforms Figure 4. HCSL Output Waveforms Figure 5. CML Output Waveforms Termination for 3.3V LVPECL Outputs Figure 6. 3.3V LVPECL Output Termination Figure 7. 3.3V LVPECL Output Termination Termination for 2.5V LVPECL Outputs Figure 8. 2.5V LVPECL Driver Termination Example Figure 9. 2.5V LVPECL Driver Termination Example Figure 10. 2.5V LVPECL Driver Termination Example LVDS Driver Termination Figure 11. Standard LVDS Termination Figure 12. Optional LVDS Termination Recommended Termination for HCSL Outputs Figure 13. Recommended Source Termination (where the driver and receiver will be on separate PCBs) Figure 14. Recommended Termination (where a point-to-point connection can be used) CML Termination Figure 15. CML Termination Example Package Outline Drawings Marking Diagrams Figure 16. Marking Configuration for the 7.0 × 5.0 mm and 5.0 × 3.2 mm Packages Figure 17. Marking Configuration for the 3.2 × 2.5 mm Package Ordering Information Revision History
