Datasheet DPS368 (Infineon) - 2
| Производитель | Infineon |
| Описание | XENSIV™ DPS368 - ultra small waterproof pressure sensor, environmentally protected against water (IPx8), dust & humidity |
| Страниц / Страница | 44 / 2 — DPS368. Typical applications. Smart watches, wearable & smart phone. … |
| Версия | 01_00 |
| Формат / Размер файла | PDF / 3.0 Мб |
DPS368. Typical applications. Smart watches, wearable & smart phone. Home appliances. Drones. Health care
21 предложений от 11 поставщиков DIGITAL PRESSURE SENSOR / Pressure Sensor 4.35PSI ~ 17.4PSI (30kPa ~ 120kPa) Vented Gauge 24 b 8-VFLGA |
| DPS368XTSA1 Infineon | 111 ₽ | |
| DPS368XTSA1
| 323 ₽ | |
| DPS368XTSA1 Infineon | 1 116 ₽ | |
| DPS368XTSA1 Infineon | по запросу | |
DPS368 Typical applications Typical applications
( e.g. altitude, fitness tracking, step counting, fall detection) •
Home appliances
(e.g. air flow control in HVAC / vacuum cleaner, water level detection, intruder detection) •
Drones
( e.g. flight stability, height control) •
Health care
(e.g. fall detection, air flow monitoring, smart inhaler)
Product Validation Qualified for industrial applications according to the relevant tests of JEDEC47/20/22.
Preliminary datasheet 2 v1.0 2019-03-14 Document Outline Product Description Features Typical applications Product Validation Table of contents 1 Definitions, acronyms and abbreviations 1.1 Definitions 2 Pin Configuration and Block Diagram 2.1 Pin Configuration and Description 2.2 Block Diagram 3 Specifications 3.1 Operating Range 3.2 Absolute Maximum Ratings 3.3 Current Consumption 3.4 Temperature Transfer Function 3.5 Pressure Transfer Function 3.6 Timing Characteristics 4 Functional Description 4.1 Operating Modes 4.2 Mode transition diagram 4.3 Start-up sequence 4.4 Measurement Precision and Rate 4.5 Sensor Interface 4.6 Interrupt 4.7 Result Register Operation 4.8 FIFO Operation 4.9 Calibration and Measurement Compensation 4.9.1 How to Calculate Compensated Pressure Values 4.9.2 How to Calculate Compensated Temperature Values 4.9.3 Compensation Scale Factors 4.9.4 Pressure and Temperature calculation flow 5 Applications 5.1 Measurement Settings and Use Case Examples 5.2 Application Circuit Example 5.3 IIR filtering 6 Digital interfaces 6.1 I2C Interface 6.2 SPI Interface 6.3 Interface parameters specification 6.3.1 General interface parameters 6.3.1.1 I2C timings 6.3.1.2 SPI timings 7 Register Map 8 Register description 8.1 Pressure Data (PRS_Bn) 8.1.1 PRS_B2 8.1.2 PRS_B1 8.1.3 PRS_B0 8.2 Temperature Data (TMP_Tn) 8.2.1 TMP_B2 8.2.2 TMP_B1 8.2.3 TMP_B0 8.3 Pressure Configuration (PRS_CFG) 8.4 Temperature Configuration(TMP_CFG) 8.5 Sensor Operating Mode and Status (MEAS_CFG) 8.6 Interrupt and FIFO configuration (CFG_REG) 8.7 Interrupt Status (INT_STS) 8.8 FIFO Status (FIFO_STS) 8.9 Soft Reset and FIFO flush (RESET) 8.10 Product and Revision ID (ID) 8.11 Calibration Coefficients (COEF) 8.12 Coefficient Source 9 Package Dimensions 9.1 Package drawing 10 Footprint and stencil recommendation 11 Reflow soldering and board assembly 12 Package Handling Revision history Disclaimer
