Datasheet DPS368 (Infineon) - 9
ПроизводительInfineon
ОписаниеXENSIV™ DPS368 - ultra small waterproof pressure sensor, environmentally protected against water (IPx8), dust & humidity
Страниц / Страница44 / 9 — DPS368. Specifications. 3.4. Temperature Transfer Function. Table 6. …
Версия01_00
Формат / Размер файлаPDF / 3.0 Мб
DPS368. Specifications. 3.4. Temperature Transfer Function. Table 6. Parameter. Symbol Values. Unit Note / Test Condition. Min. Typ. Max
DPS368 Specifications 3.4 Temperature Transfer Function Table 6 Parameter Symbol Values Unit Note / Test Condition Min Typ Max
21 предложений от 11 поставщиков
DIGITAL PRESSURE SENSOR / Pressure Sensor 4.35PSI ~ 17.4PSI (30kPa ~ 120kPa) Vented Gauge 24 b 8-VFLGA
DPS368XTSA1
Infineon
111 ₽
DPS368XTSA1
323 ₽
DPS368XTSA1
Infineon
727GS
DPS368XTSA1
Infineon
Test conditions (unless otherwise specified in the table): VDD= 1.8V and VDDIO=1.8V. Typ. values (PA=1000hPa and TA=25°C). Max./Min. values (PA= 950-1050hPa and TA=0...+65°C).
Table 6 Temperature Transfer Function Parameter Symbol Values Unit Note / Test Condition Min. Typ. Max.
Temperature accuracy At +/-0.5 °C Temperature data resolution At_res 0.01 °C Temperature measurement rate f 1 128 Hz Preliminary datasheet 9 v1.0 2019-03-14 Document Outline Product Description Features Typical applications Product Validation Table of contents 1 Definitions, acronyms and abbreviations 1.1 Definitions 2 Pin Configuration and Block Diagram 2.1 Pin Configuration and Description 2.2 Block Diagram 3 Specifications 3.1 Operating Range 3.2 Absolute Maximum Ratings 3.3 Current Consumption 3.4 Temperature Transfer Function 3.5 Pressure Transfer Function 3.6 Timing Characteristics 4 Functional Description 4.1 Operating Modes 4.2 Mode transition diagram 4.3 Start-up sequence 4.4 Measurement Precision and Rate 4.5 Sensor Interface 4.6 Interrupt 4.7 Result Register Operation 4.8 FIFO Operation 4.9 Calibration and Measurement Compensation 4.9.1 How to Calculate Compensated Pressure Values 4.9.2 How to Calculate Compensated Temperature Values 4.9.3 Compensation Scale Factors 4.9.4 Pressure and Temperature calculation flow 5 Applications 5.1 Measurement Settings and Use Case Examples 5.2 Application Circuit Example 5.3 IIR filtering 6 Digital interfaces 6.1 I2C Interface 6.2 SPI Interface 6.3 Interface parameters specification 6.3.1 General interface parameters 6.3.1.1 I2C timings 6.3.1.2 SPI timings 7 Register Map 8 Register description 8.1 Pressure Data (PRS_Bn) 8.1.1 PRS_B2 8.1.2 PRS_B1 8.1.3 PRS_B0 8.2 Temperature Data (TMP_Tn) 8.2.1 TMP_B2 8.2.2 TMP_B1 8.2.3 TMP_B0 8.3 Pressure Configuration (PRS_CFG) 8.4 Temperature Configuration(TMP_CFG) 8.5 Sensor Operating Mode and Status (MEAS_CFG) 8.6 Interrupt and FIFO configuration (CFG_REG) 8.7 Interrupt Status (INT_STS) 8.8 FIFO Status (FIFO_STS) 8.9 Soft Reset and FIFO flush (RESET) 8.10 Product and Revision ID (ID) 8.11 Calibration Coefficients (COEF) 8.12 Coefficient Source 9 Package Dimensions 9.1 Package drawing 10 Footprint and stencil recommendation 11 Reflow soldering and board assembly 12 Package Handling Revision history Disclaimer
