Datasheet ADuM3223/ADuM4223 (Analog Devices) - 8
Описание5 KV rms Isolated Precision Half-Bridge Driver, 4 A Output
Страниц / Страница20 / 8 — ADuM3223/ADuM4223. Data Sheet. ) (W. 1.8. RECOMMENDED OPERATING …
ВерсияJ
Формат / Размер файлаPDF / 538 Кб
ADuM3223/ADuM4223. Data Sheet. ) (W. 1.8. RECOMMENDED OPERATING CONDITIONS. ER W. 1.6. Table 10. 1.4. Parameter. Symbol. Min Max. Unit. VDDB. 1.2
ADuM3223/ADuM4223 Data Sheet ) (W 1.8 RECOMMENDED OPERATING CONDITIONS ER W 1.6 Table 10 1.4 Parameter Symbol Min Max Unit VDDB 1.2
32 предложений от 15 поставщиков
Изолятор интерфейса, MOSFET DRVR 4A 2Out Hi/Lo Side Non-Inv 16Pin SOIC N Tube
ЧипСити
ADUM3223WCRZ
284 ₽
ADUM3223WCRZ
564 ₽
ADUM3223WCRZ
от 700 ₽
Hi-Tech Circuit Group
ADUM3223WCRZ-RL7
link to page 15 link to page 15
ADuM3223/ADuM4223 Data Sheet ) (W 1.8 RECOMMENDED OPERATING CONDITIONS ER W 1.6 Table 10. PO 1.4 Parameter Symbol Min Max Unit VDDB 1.2
Operating Junction TJ −40 +125 °C
R P O
Temperature
1.0
Supply Voltages1
VDDA, P 0.8
VDD1 3.0 5.5 V
VDD1
V
0.6
DDA, VDDB 4.5 18 V
G P
VDD1 Rise Time TVDD1 1 V/µs
TIN 0.4 A
VDDA, VDDB Rise Time TVDDA, TVDDB 10 V/µs
ER 0.2
Maximum Input Signal Rise TVIA, TVIB 1 ms
OP
and Fall Times
FE 0 SA 0 50 100 150 200
102 Common-Mode Transient −50 +50 kV/µs
AMBIENT TEMPERATURE (°C)
Immunity, Static2 10450- Figure 2. ADuM3223 Thermal Derating Curve, Dependence of Common-Mode Transient −25 +25 kV/µs Safety-Limiting Values on Case Temperature, per DIN V VDE V 0884-10 Immunity, Dynamic3 1 All voltages are relative to their respective ground. See the Applications
Information section for information on immunity to external magnetic fields.
(W 3.0
2 Static common-mode transient immunity is defined as the largest dv/dt
ER
between GND1 and GNDA/GNDB, with inputs held either high or low such
W
that the output voltage remains either above 0.8 × VDD2 for VIA/VIB = high or
PO 2.5
0.8 V for VIA/VIB = low. Operation with transients above the recommended levels may cause momentary data upsets.
VDDB
3 Dynamic common-mode transient immunity is defined as the largest dv/dt
2.0 R P
between GND
O
1 and GNDA/GNDB, with the switching edge coincident with the transient test pulse. Operation with transients above the recommended
VDDA 1.5
, P VDD1 1.0 G P TIN A 0.5 ER OP FE 0 SA 0 50 100 150 200
103
10450- Figure 3. ADuM4223 Thermal Derating Curve, Dependence of Safety-Limiting Values on Case Temperature, per DIN V VDE V 0884-10 Rev. J | Page 8 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Characteristics—5 V Operation Electrical Characteristics—3.3 V Operation Package Characteristics Insulation and Safety-Related Specifications ADuM3223 ADuM4223 Regulatory Information DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Applications Information PC Board Layout Propagation Delay-Related Parameters Thermal Limitations and Switch Load Characteristics Output Load Characteristics Boot-Strapped Half-Bridge Operation DC Correctness and Magnetic Field Immunity Power Consumption Insulation Lifetime Outline Dimensions Ordering Guide Automotive Products
