Datasheet ADUM6132 (Analog Devices) - 4
ОписаниеIsolated Half-Bridge Driver with Integrated Isolated High-Side Supply
Страниц / Страница16 / 4 — ADuM6132. Data Sheet. Parameter. Symbol. Min. Typ. Max. Unit. Test …
ВерсияB
Формат / Размер файлаPDF / 318 Кб
ADuM6132. Data Sheet. Parameter. Symbol. Min. Typ. Max. Unit. Test Conditions/Comments. PACKAGE CHARACTERISTICS. Table 2. Parameter
ADuM6132 Data Sheet Parameter Symbol Min Typ Max Unit Test Conditions/Comments PACKAGE CHARACTERISTICS Table 2 Parameter
28 предложений от 16 поставщиков
Изолятор интерфейса, MOSFET DRVR 0.2A 2Out Hi/Lo Side Half Brdg Non-Inv 16Pin SOIC W T/R
ADUM6132ARWZ-RL
237 ₽
ADUM6132ARWZ-RL
267 ₽
Элитан
ADUM6132ARWZ
452 ₽
Эиком
ADUM6132ARWZ
от 678 ₽
link to page 10 link to page 11 link to page 6 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
Part-to-Part Matching1 60 ns CL = 200 pF Output Rise Time (10% to 90%) tR 15 ns CL = 200 pF Output Fall Time (10% to 90%) tF 15 ns CL = 200 pF 1 See the Terminology section. 2 IDDA is supplied by the output of the integrated isolated dc-to-dc power supply. IDDB is supplied by an external power connection to the VDDB pin. See Figure 16. 3 Duration less than 1 second. Average output current must conform to the limit shown in the Absolute Maximum Ratings section. 4 Undervoltage lockout (UVLO) holds the outputs in a low state if the corresponding input or output power supply is below the referenced threshold. Hysteresis is built into the detection threshold to prevent oscillations and noise sensitivity.
PACKAGE CHARACTERISTICS Table 2. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
Resistance (Input Side to High-Side Output)1 RI-O 1012 Ω Capacitance (Input Side to High-Side Output)1 CI-O 2.0 pF Input Capacitance CI 4.0 pF Junction-to-Ambient Thermal Resistance θJA 45 °C/W 4-layer PCB 1 The device is considered a two-terminal device: Pin 1 through Pin 8 are shorted together, and Pin 9 through Pin 16 are shorted together.
REGULATORY INFORMATION Table 3. UL CSA VDE (Pending)
Recognized under UL 1577 Approved under CSA Component Acceptance Certified according to DIN V VDE V 0884-10 component recognition program1 Notice #5A (VDE V 0884-10):2006-122 Single protection, Basic insulation per CSA 60950-1-03 and IEC 60950-1, Reinforced insulation, 560 V peak 3750 V rms isolation voltage 400 V rms (566 V peak) maximum working voltage Reinforced insulation per CSA 60950-1-03 and IEC 60950-1, 250 V rms (354 V peak) maximum working voltage File E214100 File 205078 File 2471900-4880-0001 1 In accordance with UL 1577, each ADuM6132 is proof-tested by applying an insulation test voltage ≥ 4500 V rms for 1 second (current leakage detection limit = 10 µA). 2 In accordance with DIN V VDE V 0884-10, each ADuM6132 is proof-tested by applying an insulation test voltage ≥ 1050 V peak for 1 second (partial discharge detection limit = 5 pC). The asterisk (*) marking branded on the component designates DIN V VDE V 0884-10 approval.
INSULATION AND SAFETY-RELATED SPECIFICATIONS Table 4. Parameter Symbol Value Unit Test Conditions/Comments
Rated Dielectric Insulation Voltage 3750 V rms 1 minute duration Minimum External Air Gap (Clearance) L(I01) >8.0 mm Measured from input terminals to output terminals, shortest distance through air Minimum External Tracking (Creepage) L(I02) >8.0 mm Measured from input terminals to output terminals, shortest distance path along body Minimum Internal Gap (Internal Clearance) 0.017 min mm Insulation distance through insulation Tracking Resistance (Comparative Tracking Index) CTI >175 V DIN IEC 112/VDE 0303 Part 1 Isolation Group IIIa Material Group (DIN VDE 0110, 1/89, Table 1) Rev. B | Page 4 of 16 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Electrical Characteristics Package Characteristics Regulatory Information Insulation and Safety-Related Specifications DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operation Conditions Absolute Maximum Values ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Applications Information Typical Application Usage PCB Layout Thermal Analysis Undervoltage Lockout Propagation Delay-Related Parameters Magnetic Field Immunity Insulation Lifetime Outline Dimensions Ordering Guide
