Datasheet ADUM6132 (Analog Devices) - 5
ОписаниеIsolated Half-Bridge Driver with Integrated Isolated High-Side Supply
Страниц / Страница16 / 5 — Data Sheet. ADuM6132. DIN V VDE V 0884-10 (VDE V 0884-10) INSULATION …
ВерсияB
Формат / Размер файлаPDF / 318 Кб
Data Sheet. ADuM6132. DIN V VDE V 0884-10 (VDE V 0884-10) INSULATION CHARACTERISTICS. Table 5. Parameter
Data Sheet ADuM6132 DIN V VDE V 0884-10 (VDE V 0884-10) INSULATION CHARACTERISTICS Table 5 Parameter
29 предложений от 17 поставщиков
DGTL ISO 3.75KV GATE DRVR 16SOIC. 200mA Gate Driver Magnetic Coupling 3750Vrms 2 Channel 16-SOIC. Isolators - Gate Drivers
Зенер
Россия и страны ТС
ADUM6132ARWZ
от 281 ₽
Элитан
ADUM6132ARWZ
452 ₽
Hi-Tech Circuit Group
ADUM6132ARWZ-RL
ADUM6132ARWZ
link to page 5 link to page 5 link to page 5 link to page 5
The ADuM6132 is suitable for reinforced electrical isolation only within the safety limit data. Maintenance of the safety data is ensured by protective circuits. The asterisk (*) marking on the package denotes DIN V VDE V 0884-10 approval.
Table 5. Parameter Test Conditions/Comments Symbol Value Unit
Installation Classification per DIN VDE 0110 For Rated Mains Voltage ≤ 150 V rms I to IV For Rated Mains Voltage ≤ 300 V rms I to III For Rated Mains Voltage ≤ 400 V rms I to II Climatic Classification 40/105/21 Pollution Degree (DIN VDE 0110, Table 1) 2 Maximum Working Insulation Voltage VIORM 560 V peak Input-to-Output Test Voltage, Method B1 VIORM × 1.875 = VPR, 100% production test, tm = 1 sec, VPR 1050 V peak partial discharge <5 pC Input-to-Output Test Voltage, Method A VPR After Environmental Tests Subgroup 1 VIORM × 1.6 = VPR, tm = 60 sec, partial discharge <5 pC 896 V peak After Input and/or Safety Test Subgroup 2 VIORM × 1.2 = VPR, tm = 60 sec, partial discharge <5 pC 672 V peak and Subgroup 3 Highest Allowable Overvoltage Transient overvoltage, tTR = 10 sec VTR 6000 V peak Safety-Limiting Values Maximum value allowed in the event of a failure (see Figure 2) Case Temperature TS 150 °C Side 1 Current IS1 555 mA Insulation Resistance at TS VIO = 500 V RS >109 Ω
600 RECOMMENDED OPERATING CONDITIONS 500 mA) Table 6. ( NT Parameter Rating 400
Operating Temperature Range, TA −40°C to +85°C
CURRE
Input Supply Voltage, V 1 DD and VDDL 4.5 V to 5.5 V
DD 300
Channel A, Channel B Supply Voltage, 12.5 V to 17 V
G V
V 1
TIN
DDA and VDDB
A R 200
Input Signal Rise and Fall Times 1 ms
E OP
Common-Mode Transient Immunity, −50 kV/µs to +50 kV/µs
FE 100
Input to Output
A S
Minimum Power-On Slew Rate (PSLEW), 1 V/ms 2
0
VDD and VDDL
0 50 100 150 200
002
AMBIENT TEMPERATURE (°C)
1 All voltages are relative to their respective ground. 07393- 2 Figure 2. Thermal Derating Curve, Dependence of Safety-Limiting Values The ADuM6132 power supply may fail to properly initialize if VDD and VDDL are applied too slowly. The power supply slew rate must be faster than specified with Ambient Temperature per DIN V VDE V 0884-10 over the entire turn-on ramp. Power-on should start from a completely discharged state. Rev. B | Page 5 of 16 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Electrical Characteristics Package Characteristics Regulatory Information Insulation and Safety-Related Specifications DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operation Conditions Absolute Maximum Values ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Applications Information Typical Application Usage PCB Layout Thermal Analysis Undervoltage Lockout Propagation Delay-Related Parameters Magnetic Field Immunity Insulation Lifetime Outline Dimensions Ordering Guide
