Datasheet ADUM5230 (Analog Devices) - 4
ОписаниеIsolated Half-Bridge Driver with Integrated High-Side Supply
Страниц / Страница15 / 4 — ADuM5230. Data Sheet. Parameter. Symbol. Min. Typ. Max. Unit. Test …
ВерсияC
Формат / Размер файлаPDF / 779 Кб
ADuM5230. Data Sheet. Parameter. Symbol. Min. Typ. Max. Unit. Test Conditions/Comments
ADuM5230 Data Sheet Parameter Symbol Min Typ Max Unit Test Conditions/Comments
36 предложений от 19 поставщиков
DGTL ISO 2.5KV GATE DRVR 16SOIC. Gate Driver Magnetic Coupling 2500Vrms 2 Channel 16-SOIC. Isolators - Gate Drivers
ADUM5230ARWZ
91 ₽
Рутоника
ADUM5230ARWZ
258 ₽
ADUM5230ARWZ
от 1 229 ₽
Hi-Tech Circuit Group
ADUM5230ARWZ
link to page 6
Part to Part Matching, Rising or Fal ing Edges7 55 ns CL = 200 pF Part to Part Matching, Rising vs. Falling Edges8 63 ns CL = 200 pF Common-Mode Transient Immunity at |CMH| 25 35 kV/µs VIx = VDD1, VCM = 1000 V, Logic High Output transient magnitude = 800 V Common-Mode Transient Immunity at |CML| 25 35 kV/µs VIx = 0 V, VCM = 1000 V, Logic Low Output transient magnitude = 800 V Output Rise Time (10% to 90%) tR 25 ns CL = 200 pF, IISO = 10 mA, 100 kHz switching frequency Output Fall Time (10% to 90%) tF 10 ns CL = 200 pF, IISO = 10 mA, 100 kHz switching frequency 1 Short-circuit duration is less than 1 sec. Average output current must conform to the limit shown under the Absolute Maximum Ratings section. 2 The minimum pulse width is the shortest pulse width at which the specified timing parameters are guaranteed. Operation below the minimum pulse width is strongly discouraged because in some instances pulse stretching to 1 µs may occur. 3 The maximum switching frequency is the maximum signal frequency at which the specified timing and power conversion parameters are guaranteed. Operation above the maximum frequency is strongly discouraged. 4 tPHL propagation delay is measured from the 50% level of the falling edge of the VIx signal to the 50% level of the falling edge of the VOx signal. tPLH propagation delay is measured from the 50% level of the rising edge of the VIx signal to the 50% level of the rising edge of the VOx signal. 5 In channel-to-channel matching, the rising or falling matching edge polarity is the magnitude of the propagation delay difference between two channels of the same part when both inputs are either both rising or falling edges. The loads on each channel are equal. 6 In channel-to-channel matching, the rising vs. falling opposite edge polarity is the magnitude of the propagation delay difference between two channels of the same part when one input is a rising edge and one input is a falling edge. The loads on each channel are equal. 7 Part-to-part matching, rising or falling edges, is the magnitude of the propagation delay difference between the same channels of two different parts when the inputs are either both rising or falling edges. The supply voltages, temperatures, and loads of each part are equal. 8 Part-to-part matching, rising vs. falling edges, is the magnitude of the propagation delay difference between the same channels of two different parts when one input is a rising edge and the other input is a falling edge. The supply voltages, temperatures, and loads of each part are equal. Rev. C | Page 4 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS PACKAGE CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY-RELATED SPECIFICATIONS RECOMMENDED OPERATING CONDITIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFOMANCE CHARACTERISTICS APPLICATIONS INFORMATION THEORY OF OPERATION PRINTED CIRCUIT BOARD (PCB) LAYOUT THERMAL ANALYSIS PROPAGATION DELAY-RELATED PARAMETERS DC CORRECTNESS AND MAGNETIC FIELD IMMUNITY POWER CONSUMPTION INCREASING AND DECREASING AVAILABLE POWER COMMON-MODE TRANSIENT IMMUNITY TYPICAL APPLICATION USAGE INSULATION LIFETIME OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
