Линейка продуктов KEEN SIDE
Datasheet LZ1-00NW05 (LedEngin) - 5
ПроизводительLedEngin
ОписаниеHigh Luminous Efficacy 5W Neutral White LED
Страниц / Страница13 / 5 — Soak Requirements. Floor Life. Standard. Accelerated. Level. Led
Формат / Размер файлаPDF / 280 Кб
Soak Requirements Floor Life Standard Accelerated Level Led
Светодиоды высокой мощности - белые Neutral White 5 Watt
LZ1-00NW05
LZ1-00NW05
LedEngin
IPC/JEDEC Moisture Sensitivity Level Table 4 - IPC/JEDEC J-STD-20D.1 MSL Classification:
Time Conditions Time (hrs) Conditions Time (hrs) Conditions ≤ 30°C/ 168 85°C/ 1 Unlimited n/a n/a 85% RH +5/-0 85% RH Notes for Table 4: 1. The standard soak time includes a default value of 24 hours for semiconductor manufacturer’s exposure time (MET) between bake and bag and includes the maximum time allowed out of the bag at the distributor’s facility. Average Lumen Maintenance Projections Lumen maintenance generally describes the ability of a lamp to retain its output over time. The useful lifetime for solid state lighting devices (Power LEDs) is also defined as Lumen Maintenance, with the percentage of the original light output remaining at a defined time period. Based on long-term WHTOL testing, LedEngin projects that the LZ Series will deliver, on average, 90% Lumen Maintenance at 100,000 hours of operation at a forward current of 1000 mA. This projection is based on constant current operation with junction temperature maintained at or below 125°C. Typical Radiation Pattern 100 90 80 70 (%) 60 50 Intensity e 40 30 Relativ 20 10 0 -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Angular Displacement (Degrees) Figure 2: Typical representative spatial radiation pattern.
Led
Engin, Inc. 5 LZ1-00NW05 (01/11/10)
