Datasheet LZ1-00NW05 (LedEngin) - 6
ПроизводительLedEngin
ОписаниеHigh Luminous Efficacy 5W Neutral White LED
Страниц / Страница13 / 6 — Parameter Symbol. Value. Unit. Typical. Led
Формат / Размер файлаPDF / 280 Кб
Parameter Symbol Value Unit Typical Led
Светодиоды высокой мощности - белые Neutral White 5 Watt
LZ1-00NW05
LZ1-00NW05
LedEngin
Absolute Maximum Ratings Table 5:
DC Forward Current [1] IF 1500 mA Peak Pulsed Forward Current [2] IFP 2000 mA Reverse Voltage VR See Note 3 V Storage Temperature Tstg -40 ~ +150 °C Junction Temperature TJ 150 °C Soldering Temperature [4] Tsol 260 °C Allowable Reflow Cycles 6 121°C at 2 ATM, Autoclave Conditions [5] 100% RH for 168 hours > 8,000 V HBM ESD Sensitivity [6] Class 3B JESD22-A114-D Notes for Table 5: 1. Maximum DC forward current is determined by the overall thermal resistance and ambient temperature. Follow the curves in Figure 10 for current derating. 2: Pulse forward current conditions: Pulse Width ≤ 10msec and Duty Cycle ≤ 10%. 3. LEDs are not designed to be reverse biased. 4. Solder conditions per JEDEC 020D. See Reflow Soldering Profile Figure 5. 5. Autoclave Conditions per JEDEC JESD22-A102-C. 6. LedEngin recommends taking reasonable precautions towards possible ESD damages and handling the LZ1-00NW05 in an electrostatic protected area (EPA). An EPA may be adequately protected by ESD controls as outlined in ANSI/ESD S6.1. Optical Characteristics @ TC = 25°C Table 6:
Parameter Symbol Typical Unit
Luminous Flux (@ IF = 1000mA) ΦV 190 lm Luminous Flux (@ IF = 1500mA) ΦV 240 lm Luminous Efficacy (@ IF = 350mA) 80 lm/W Correlated Color Temperature CCT 4000 K Chromaticity Coordinates x,y 0.381, 0.377 Color Rendering Index (CRI) Ra 75 Viewing Angle [1] 2Θ1/2 85 Degrees Total Included Angle [2] Θ0.9V 125 Degrees Notes for Table 6: 1. Viewing Angle is the off axis angle from emitter centerline where the luminous intensity is ½ of the peak value. 2. Total Included Angle is the total angle that includes 90% of the total luminous flux. Electrical Characteristics @ TC = 25°C Table 7:
Forward Voltage (@ IF = 1000mA) VF 3.6 V Forward Voltage (@ IF = 1500mA) VF 3.8 V Temperature Coefficient ∆V of Forward Voltage F/∆TJ -2.8 mV/°C Thermal Resistance RΘ (Junction to Case) J-C 5.5 °C/W
Led
Engin, Inc. 6 LZ1-00NW05 (01/11/10)
