Datasheet Teseo-LIV3R (STMicroelectronics) - 5
ПроизводительSTMicroelectronics
ОписаниеTeseo ROM GNSS module
Страниц / Страница30 / 5 — Teseo-LIV3R. General description. 1.2 Block. diagram. Figure 1. …
Формат / Размер файлаPDF / 864 Кб
Teseo-LIV3R. General description. 1.2 Block. diagram. Figure 1. Teseo-LIV3R block schematic
Teseo-LIV3R General description 1.2 Block diagram Figure 1 Teseo-LIV3R block schematic
34 предложений от 13 поставщиков
GPS Receiver 1575.42MHz 4.3V Automotive 18-Pin LLCC T/R
727GS
TESEO-LIV3R
921 ₽
TESEO-LIV3R
1 013 ₽
ЧипСити
TESEO-LIV3R
1 022 ₽
TESEO-LIV3R
1 082 ₽
3. For hot start, all sats have the same signal level except one (pilot sat at -145 dBm). 4. For BEIDOU tracking sensitivity refers to MEO sats. For GEO the tracking sensitivity is -151 dBm 5. Configurable Value. 6. All satellites at same signal level. 7. Minimum level to get valid fix after reacquisition. 8. 50% at 30 m/s - linear path. 9. 50% at 0.5 g - shape path. 10. CEP 50%, 24h static, Roof Antenna. 11. Verified the limit checking the fix availability. 12. Special configuration for high dynamic scenario. 13. To be compliant with USA International Traffic in Arms Regulations (ITAR), when both the ITAR altitude limit and the ITAR velocity limit are overpass taken the Teseo-LIV3R stops providing NMEA stream.
1.2 Block diagram Figure 1. Teseo-LIV3R block schematic
DS12821 Rev 2 5/30 29 Document Outline Table 1. Device summary 1 General description 1.1 GNSS performance Table 2. GNSS performance 1.2 Block diagram Figure 1. Teseo-LIV3R block schematic 1.3 Pin configuration Figure 2. Teseo-LIV3R pin layout 1.4 Pin out description Table 3. Teseo-LIV3R pin out description 2 Supported GNSS constellations 2.1 GPS 2.2 GLONASS 2.3 BeiDou 3 Augmentation systems 3.1 Satellite-Based augmentation system 3.2 QZSS 3.3 Differential GPS Table 4. Supported RTCM message on Teseo-LIV3R 4 Assisted GNSS 4.1 RealTime AGNSS 5 Clock generation 5.1 Temperature-Compensated Crystal Oscillator (TCXO) 5.2 Real Time Clock (RTC) 6 I/O interfaces 6.1 UART 6.2 I2C 7 FW configuration 8 Power mode 8.1 Hardware standby 8.2 Software standby 9 Geofencing 10 Odometer 11 Regulatory compliance 11.1 CE certification for Teseo-LIV3R Figure 3. CE marking 12 Electrical characteristics 12.1 Parameter conditions 12.2 Minimum and maximum values 12.3 Typical values 12.4 Absolute maximum ratings Table 5. Voltage characteristics Table 6. Thermal characteristics Table 7. Power consumption 12.5 Recommended DC operating conditions Table 8. Recommended DC operating conditions 13 Mechanical specifications Figure 4. Teseo-LIV3R mechanical specification 14 Shipping information 14.1 Reels Figure 5. Carrier tape Figure 6. Teseo-LIV3R orientation Figure 7. Cover tape Figure 8. Plastic reel Figure 9. PB band 14.2 Packing cartons for reels 14.3 ESD handling precautions 14.4 Moisture sensitivity levels 15 Labeling information Figure 10. Labeling information of Teseo-LIV3R Table 9. Labeling information description 16 Reflow soldering profile Table 10. Soldering profile values Figure 11. Soldering profiles 17 ECOPACK® Appendix A Reference document Revision history Table 11. Revision history
