Datasheet TC78B041FNG, TC78B042FTG (Toshiba) - 10
ПроизводительToshiba
ОписаниеSinewave PWM brushless motor control / Auto lead angle function. Brushless motor driver IC
Страниц / Страница44 / 10 — Absolute maximum ratings (Ta = 25°C)
Формат / Размер файлаPDF / 585 Кб
31 предложений от 11 поставщиков
Микросхема: 3 PHASE BLDC CONTROLLER
TC78B042FTG,EL
Toshiba
152 ₽
TC78B042FTG,EL
177 ₽
Эиком
TC78B042FTG,EL
Toshiba
от 208 ₽
Hi-Tech Circuit Group
TC78B042FTG,EL
TC78B041FNG/TC78B042FTG
Characteristics Symbol Rating Unit Remarks Power supply voltage MV CC 18 V VCC MVIN1 - 0.3 to 18 V VSP HUP, HVP, HWP, HUM, HVM, HWM, MVIN2 - 0.3 to VREF+ 0.3 V Input voltage TR, OSCR, FGC, LA, LAS, LAL, MODE, LAAJ, RES MVIN3 - 0.3 to 6 V RESX, CWCCW MVIN4 VREF+ 0.3 V IDC, RSI MVout1 6 V VREF, VREF2 Output voltage MVout2 - 0.3 to VREF+ 0.3 V FG, UH, VH, WH, UL, VL, WL Output current MIOUT 2 mA FG, UH, VH, WH, UL,VL, WL VREF (VREF+VREF2)(Note) VREF output current MIrefout 35 mA (VREF2 output current is also included.) VREF2 output current MIrefout2 3 mA VREF2 (Note) TC78B041FNG (SSOP30) PD1 1.87 W When mounted on JEDEC 4-layer board Power dissipation TC78B042FTG (QFN32) PD2 4.25 W When mounted on JEDEC 4-layer board Operating temperature range is determined according to the characteristics of power dissipation. The Operating temperature Topr - 40 to 115 °C maximum junction temperature should not exceed Tj (max) (150°C). Storage temperature Topr - 55 to 150 °C ― The absolute maximum ratings of a semiconductor device are a set of ratings that must not be exceeded, even for a moment. Do not exceed any of these ratings. Exceeding the rating (s) may cause the device breakdown, damage or deterioration, and may result injury by explosion or combustion. Please use the IC within the specified operating ranges. Note: VREF2 pin is only for the TC78B042FTG. 10 2018-11-27
