Datasheet ACS715 (Allegro) - 4
ПроизводительAllegro
ОписаниеAutomotive Grade, Fully Integrated, Hall Effect-Based Linear Current Sensor IC with 2.1 kVRMS Voltage Isolation and a Low-Resistance Current Conductor
Страниц / Страница16 / 4 — Automotive Grade, Fully Integrated, Hall-Effect-Based Linear Current …
Automotive Grade, Fully Integrated, Hall-Effect-Based Linear Current Sensor IC. ACS715
Automotive Grade, Fully Integrated, Hall-Effect-Based Linear Current Sensor IC ACS715
31 предложений от 14 поставщиков
Сенсоры, Датчики Датчики тока
ACS715LLCTR-20A-T
Allegro
от 67 ₽
ACS715LLCTR-20A-T
Allegro
455 ₽
Эиком
ACS715LLCTR-20A-T
Allegro
от 634 ₽
727GS
ACS715LLCTR-20A-T
Allegro
28 981 ₽
Automotive Grade, Fully Integrated, Hall-Effect-Based Linear Current Sensor IC ACS715 with 2.1 kVRMS Voltage Isolation and Low-Resistance Current Conductor SPECIFICATIONS Absolute Maximum Ratings Characteristic Symbol Notes Rating Unit
Supply Voltage VCC 8 V Reverse Supply Voltage VRCC –0.1 V Output Voltage VIOUT 8 V Reverse Output Voltage VRIOUT –0.1 V Output Current Source IOUT(Source) 3 mA Output Current Sink IOUT(Sink) 10 mA Overcurrent Transient Tolerance IP 1 pulse, 100 ms 100 A Range E –40 to 85 ºC Nominal Operating Ambient Temperature TA Range L –40 to 150 ºC Maximum Junction Temperature TJ(max) 165 ºC Storage Temperature Tstg –65 to 170 ºC
Isolation Characteristics Characteristic Symbol Notes Rating Unit
Dielectric Strength Test Voltage* V Agency type-tested for 60 seconds per ISO UL standard 60950-1, 1st Edition 2100 VAC Working Voltage for Basic Isolation V For basic (single) isolation per UL standard 60950-1, 1st WFSI Edition 354 VDC or Vpk Working Voltage for Reinforced Isolation V For reinforced (double) isolation per UL standard 60950- WFRI 1, 1st Edition 184 VDC or Vpk * Allegro does not conduct 60-second testing. It is done only during the UL certification process. 3 Allegro MicroSystems 955 Perimeter Road Manchester, NH 03103-3353 U.S.A. www.allegromicro.com
