Datasheet ACS780xLR (Allegro) - 4
ПроизводительAllegro
ОписаниеHigh-Precision Linear Hall-Effect-Based Current Sensor IC With 200 μΩ Current Conductor
Страниц / Страница25 / 4 — High-Precision Linear Hall-Effect-Based. ACS780xLR. Current Sensor IC …
Формат / Размер файлаPDF / 2.7 Мб
High-Precision Linear Hall-Effect-Based. ACS780xLR. Current Sensor IC With 200 µΩ Current Conductor. Functional Block Diagram
High-Precision Linear Hall-Effect-Based ACS780xLR Current Sensor IC With 200 µΩ Current Conductor Functional Block Diagram
35 предложений от 11 поставщиков
Датчики и Аксессуары, Current Sensor AC-DC Current 5V Automotive 7Pin PSOF T/R
ACS780LLRTR-050U-T
Allegro
от 91 ₽
ACS780LLRTR-050U-T
Allegro
от 158 ₽
ACS780LLRTR-050U-T
Allegro
405 ₽
ACS780LLRTR-050U-T
Allegro
3 969 ₽
IP+ VCC ACS780xLR To all subcircuits Master Current Supply Temperature EEPROM and Programming Sensor Control Logic Control Hall Current Drive Sensitivity Offset Control Control fset VOUT Tuned Amp Filter Cancellation Dynamic Of GND IP–
NC
Terminal List Table
4 IP+ 5 3 VOUT
Number Name Description
1 VCC Device power supply terminal 2 GND 2 GND Signal ground terminal 3 VOUT Analog output signal IP– 6 1 VCC 7 4 NC No connection, connect to GND for optimal ESD performance NC 5 IP+ Terminal for current being sampled 6 IP– Terminal for current being sampled
Pinout Diagram
7 NC No connection, connect to GND for optimal ESD performance Allegro MicroSystems, LLC 4 955 Perimeter Road Manchester, NH 03103-3353 U.S.A. www.allegromicro.com
