Datasheet AD7655-EP (Analog Devices) - 3
ОписаниеLow Cost, 4-Channel, 16-Bit, 500 kSPS PulSAR ADC
Страниц / Страница12 / 3 — Enhanced Product. AD7655-EP. SPECIFICATIONS. Table 2. Parameter. …
ВерсияB
Формат / Размер файлаPDF / 268 Кб
Enhanced Product. AD7655-EP. SPECIFICATIONS. Table 2. Parameter. Conditions. Min. Typ. Max. Unit
Enhanced Product AD7655-EP SPECIFICATIONS Table 2 Parameter Conditions Min Typ Max Unit
34 предложений от 16 поставщиков
Микросхема Преобразователь AD, ADC Single SAR 1MSPS 16Bit Parallel/Serial 48Pin LFCSP EP
727GS
AD7655ACPZ
от 188 ₽
AD7655ACPZ
от 2 933 ₽
Эиком
AD7655ACPZ
от 3 183 ₽
AD7655ACPZ
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
AVDD = DVDD = 5 V, OVDD = 2.7 V to 5.25 V; VREF = 2.5 V; all specifications TMIN to TMAX, unless otherwise noted.
Table 2. Parameter Conditions Min Typ Max Unit
RESOLUTION 16 Bits ANALOG INPUT Voltage Range VINx – VINxN 0 2 VREF V Common-Mode Input Voltage VINxN −0.1 +0.5 V Analog Input CMRR fIN = 100 kHz 55 dB Input Current 1 MSPS throughput 45 µA Input Impedance THROUGHPUT SPEED Complete Cycle (2 Channels) Normal mode 2 µs Throughput Rate Normal mode 0 1 MSPS Complete Cycle (2 Channels) Impulse mode 2.25 µs Throughput Rate Impulse mode 0 888 kSPS DC ACCURACY Integral Linearity Error1 −6 +6 LSB2 No Missing Codes 15 Bits Transition Noise 0.8 LSB Full-Scale Error TMIN to TMAX ±0.25 ±0.5 % of FSR Full-Scale Error Drift ±2 ppm/°C Unipolar Zero Error TMIN to TMAX ±0.25 % of FSR Unipolar Zero Error Drift ±0.8 ppm/°C Power Supply Sensitivity AVDD = 5 V ± 5% ±0.8 LSB AC ACCURACY Signal-to-Noise fIN = 100 kHz 86 dB3 Spurious-Free Dynamic Range fIN = 100 kHz 98 dB Total Harmonic Distortion fIN = 100 kHz −96 dB Signal-to-Noise and Distortion fIN = 100 kHz 86 dB fIN = 100 kHz, −60 dB input 30 dB Channel-to-Channel Isolation fIN = 100 kHz −92 dB −3 dB Input Bandwidth 10 MHz SAMPLING DYNAMICS Aperture Delay 2 ns Aperture Delay Matching 30 ps Aperture Jitter 5 ps rms Transient Response Full-scale step 250 ns REFERENCE External Reference Voltage Range 2.3 2.5 AVDD/2 V External Reference Current Drain 1 MSPS throughput 180 µA DIGITAL INPUTS Logic Levels VIL −0.3 +0.8 V VIH +2.0 DVDD + 0.3 V IIL −1 +1 µA IIH −1 +1 µA DIGITAL OUTPUTS Data Format4 Pipeline Delay5 VOL ISINK = 1.6 mA 0.4 V VOH ISOURCE = −500 µA OVDD − 0.2 V Rev. B | Page 3 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
