Datasheet MAX9727 (Maxim) - 3
ПроизводительMaxim
ОписаниеQuad Audio Line Driver with 3VRMS Output
Страниц / Страница13 / 3 — Quad Audio Line Driver with 3VRMS Output. MAX9727. ELECTRICAL …
Формат / Размер файлаPDF / 526 Кб
Quad Audio Line Driver with 3VRMS Output. MAX9727. ELECTRICAL CHARACTERISTICS. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS
Quad Audio Line Driver with 3VRMS Output MAX9727 ELECTRICAL CHARACTERISTICS PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
IC AMP CLASS AB QUAD 20QSOP. Amplifier IC 4-Channel (Quad) Class AB 20-QSOP. Linear - Amplifiers - Audio
МосЧип
MAX9727EEP+T
Maxim
Рутоника
MAX9727EEP+T
Maxim
MAX9727EEP+T
Maxim
MAX9727EEP+T
(VDD = PVDD = 3.3V, PGND = 0V, SHDN = VDD, VCM = 0V, C1 = C2 = 1µF, RIN = RF = 5kΩ, RL = ∞, TA = TMIN to TMAX. Typical val- ues are at TA = +25°C.) (Note 1)
VOUT = 1.6VRMS, BW = 22Hz to 22kHz, f = 1kHz, unweighted, RL = 10kΩ 0.0005 Total Harmonic Distortion Plus VOUT = 2VRMS, BW = 22Hz to 22kHz, THD+N % Noise f = 1kHz, unweighted, RL = 10kΩ 0.0006 VOUT = 1.6VRMS, BW = 22Hz to 22kHz, f = 1kHz, unweighted, RL = 1kΩ 0.003 V 22Hz to 22kHz 109 OUT = 1.6VRMS, RL = 1kΩ A-weighted 113.6 Signal-to-Noise Ratio SNR dB V 22Hz to 22kHz 111 OUT = 2VRMS, RL = 1kΩ A-weighted 115.5 Peak voltage, Into shutdown -62.2 Click-and-Pop Level KCP A-weighted, 32 dBV samples/s (Notes 2, 3) Out of shutdown -54.3 Slew Rate RL = 1kΩ, CL = 100pF 0.9 V/µs Turn-On Time tON 90 µs Turn-Off Time tOFF 1 µs Capacitive Drive CL No sustained oscillations 220 pF Crosstalk f = 10kHz -70 dB Large-Signal Open-Loop Gain AVOL VOUT = 2VRMS 82 dB Small-Signal Open-Loop Gain AVOS VOUT = 100mVRMS 95 dB Gain Bandwidth GBW 3 MHz Charge-Pump Switching fOSC 150 300 450 kHz Frequency Charge-Pump Output Impedance Measured at PVSS 20 Ω ESD Protection ESD HBM ±8 kV
DIGITAL INPUTS (
SHDN
Input-Voltage High VIH 2.0 V Input-Voltage Low VIL 0.8 V Input Leakage Current ILEAK ±1 µA
Note 1:
All devices are 100% tested at TA = +25°C. Specifications over temperature are guaranteed by design.
Note 2:
Inputs AC-coupled to PGND.
Note 3:
Click-and-pop testing performed with a 1kΩ resistive load connected to ground. Mode transitions are controlled by SHDN. KCP level is calculated as 20log[(peak voltage during mode transition, no input signal)/1VRMS]. Units are expressed in dBV.
_______________________________________________________________________________________ 3
