Datasheet ADA4625-1, ADA4625-2 (Analog Devices) - 7
Описание36 V, 18 MHz, Low Noise, Fast Settling Single Supply, RRO, JFET Op Amp
Страниц / Страница35 / 7 — Data Sheet. ADA4625-1/. ADA4625-2. ABSOLUTE MAXIMUM RATINGS Table 4. …
ВерсияA
Data Sheet. ADA4625-1/. ADA4625-2. ABSOLUTE MAXIMUM RATINGS Table 4. THERMAL RESISTANCE. Parameter. Rating
Data Sheet ADA4625-1/ ADA4625-2 ABSOLUTE MAXIMUM RATINGS Table 4 THERMAL RESISTANCE Parameter Rating
46 предложений от 15 поставщиков
SOIC8;Усилитель операционный малошумящий полный вход-выход ±18В/36В 8-Pin SOIC N EP туба
ADA4625-1ARDZ-R7
от 195 ₽
Microfind
ADA4625-1ARDZ-R7
от 621 ₽
ADA4625-1ARDZ-R7
от 679 ₽
Эиком
ADA4625-1ARDZ-R7
от 1 177 ₽
link to page 32
Data Sheet ADA4625-1/ ADA4625-2 ABSOLUTE MAXIMUM RATINGS Table 4. THERMAL RESISTANCE Parameter Rating
Thermal performance is directly linked to printed circuit board Supply Voltage 40 V (PCB) design and operating environment. Close attention to PCB Input Voltage (V−) − 0.2 V to thermal design is required. (V+ ) + 0.2 V Differential Input Voltage (V−) − 0.2 V to
Table 5. Thermal Resistance
(V+) + 0.2 V
Package Type1, 2 θ 3 JA θJC Unit
Input Current1 ±20 mA RD-8-1 52.8 5.7 °C/W Storage Temperature Range −65°C to +150°C 1 Values were obtained per JEDEC standard JESD-51. Operating Temperature Range −40°C to +125°C 2 Although the exposed pad can be left floating, it must be connected to the Junction Temperature Range −65°C to +150°C GND, or the V+ or V− plane for proper thermal management. 3 Lead Temperature, Soldering (10 sec) 300°C Board layout impacts thermal characteristics such as θJA. When proper thermal management techniques are used, a better θJA can be achieved. Refer to the Electrostatic Discharge (ESD) Thermal Management section for additional information. Human Body Model (HBM)2 ADA4625-1 1.25 kV
ESD CAUTION
ADA4625-2 1.5 kV Field Induced Charge Device Model (FICDM)3 ADA4625-1 1.25 kV ADA4625-2 1.25 kV 1 The input pins have clamp diodes connected to the power supply pins. Limit the input current to 20 mA or less whenever input signals exceed the power supply rail by 0.3 V. 2 ESDA/JEDEC JS-001-2011 applicable standard. 3 JESD22-C101 (ESD FICDM standard of JEDEC) applicable standard. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. A | Page 7 of 35 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—±18 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT AND GAIN STAGES OUTPUT STAGE NO PHASE INVERSION SUPPLY CURRENT APPLICATIONS INFORMATION ACTIVE LOOP FILTER FOR PHASE-LOCKED LOOPS (PLLS) PLL Basic Loop Filter ADA4625-1 ADVANTAGES AND DESIGN EXAMPLE TRANSIMPEDANCE AMPLIFIER Design Example DAC OUTPUT DRIVER RECOMMENDED POWER SOLUTION INPUT OVERVOLTAGE PROTECTION DRIVING CAPACITIVE LOADS THERMAL MANAGEMENT TYPICAL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
