Datasheet AD7768-1 (Analog Devices) - 9
ОписаниеDC to 204 kHz, Dynamic Signal Analysis, Precision 24-Bit ADC with Power Scaling
Страниц / Страница80 / 9 — Data Sheet. AD7768-1. Parameter. Test Conditions/Comments. Min. Typ. Max. …
ВерсияA
Формат / Размер файлаPDF / 1.8 Мб
Data Sheet. AD7768-1. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD7768-1 Parameter Test Conditions/Comments Min Typ Max Unit
27 предложений от 14 поставщиков
, 1-Channel Single ADC Delta-Sigma 1.024Msps 24-bit Serial 28-Pin LFCSP EP Tray
IC Home
AD7768-1BCPZ-RL
859 ₽
AD7768-1BCPZ
1 071 ₽
T-electron
AD77681BCPZ
70 166 ₽
AD7768-1BCPZ-RL7
POWER SUPPLY CURRENT Fast Mode AVDD1 Current All buffers off, VCM off 2.2 2.65 mA Analog input precharge on (defaults on in 4.1 5.1 mA PIN mode) Precharge reference buffer (per precharge 1.2 1.5 mA buffer, defaults on in PIN mode ) Ful reference buffer (per buffer) 3.2 4.15 mA VCM output on 0.21 mA AVDD2 Current 4.7 5.65 mA IOVDD Current Sinc5 filter||low ripple FIR filter 3.35||9.2 4.4||11.5 mA Median Mode AVDD1 Current All buffers off 1.2 1.35 mA Analog input precharge on (PIN mode 2.45 2.6 mA default) Precharge reference buffer (per precharge 0.65 0.77 mA buffer) Ful reference buffer (per buffer) 1.6 2.1 mA AVDD2 Current 2.7 3.2 mA IOVDD Current Sinc5 filter||low ripple FIR filter 1.97||5 2.8||6.4 mA Low Power Mode AVDD1 Current All buffers off 0.3 0.35 mA Analog input precharge on (PIN mode 0.6 0.71 mA default) Precharge reference buffer (per precharge 0.16 0.22 mA buffer) Ful reference buffer (per buffer) 0.4 0.56 mA AVDD2 Current 1.15 1.37 mA IOVDD Current Sinc5 filter||low ripple FIR filter, 0.95||1.7 1.6||2.45 mA 16.384 MHz MCLK, MCLK_DIV = 16 Power Saving States Standby Mode Serial peripheral interface (SPI) active, 400 µA MCLK active, VCM off SPI active, MCLK inactive, VCM off 50 µA Power-Down Mode Full power-down; SPI control mode only 5 µA POWER DISSIPATION AVDD1 = 5 V, MCLK = 16.384 MHz, external complementary metal oxide semiconductor (CMOS) MCLK Sinc5 Filter AVDD2 = 2 V, IOVDD = 1.8 V Fast Mode Al buffers off 26.4 32.5 mW Analog input (AIN) precharge only 35.6 44.75 mW Median Mode Al buffers off 14.4 18.2 mW AIN precharge only 19.1 24.45 mW Low Power Mode Al buffers off 5.4 7.4 mW AIN precharge only 6.8 9.2 mW Low Ripple FIR Filter AVDD2 = 2 V, IOVDD = 1.8 V Fast Mode Al buffers off 36.8 45.25 mW AIN precharge only 46.1 57.5 mW Median Mode Al buffers off 19.7 24.7 mW AIN precharge only 24.4 30.95 mW Low Power Mode Al buffers off 6.75 8.9 mW AIN precharge only 8.1 10.7 mW Rev. A | Page 9 of 80 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS 3 V OPERATION TIMING SPECIFICATIONS 1.8 V TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CLOCKING, SAMPLING TREE, AND POWER SCALING Power vs. Noise Performance Optimization Example of Power vs. Noise Performance Optimization Configuration A Configuration B NOISE PERFORMANCE AND RESOLUTION CORE CONVERTER ADC Core and Signal Chain Analog Inputs and Precharge Buffering VCM Output Reference Input and Buffering CLOCKING AND CLOCK SELECTION CLKSEL Pin Using the Internal Oscillator DIGITAL FILTERING Sinc5 Filter Sinc3 Filter Programming for 50 Hz, 60 Hz, and 50 Hz and 60 Hz Rejection Low Ripple FIR Filter DECIMATION RATE CONTROL ANTIALIASING FILTERING Modulator Saturation Point Modulator Unprotected Zones Modulator Chopping Frequency GETTING STARTED Method of Configuration—PINB Control Mode or SPI Control Mode Digital Filter Type and Decimation Power Mode POWER SUPPLIES Single-Supply Mode Recommended Power Supply Configuration DEVICE CONFIGURATION METHOD PINB Configuration SPI Control PIN CONTROL MODE OVERVIEW Power Mode Data Output Format Diagnostics and Status Bits Daisy-Chaining—PINB Control Mode Only SPI CONTROL OVERVIEW SPI CONTROL MODE MCLK Source and MCLK Division Power-Down Mode Standby Mode SPI Synchronization Offset Calibration Gain Calibration Reset over SPI Control Interface Resume from Shutdown GPIO and STARTB Functions SPI Mode Diagnostic Features Reference Detection Clock Qualification CRC on SPI Transaction Flags for Detection of Illegal Register Write CRC Checks POR Monitor MCLK Counter Product Identification (ID) Number DIGITAL INTERFACE SPI Reading and Writing SPI Control Interface Error Handling CRC Check on Serial Interface Conversion Read Modes Single-Conversion Read Mode Continuous Read Mode Exiting Continuous Read Mode DATA CONVERSION MODES Continuous Conversion Mode One Shot Conversion Mode Single-Conversion Mode Duty Cycled Conversion Mode SYNCHRONIZATION OF MULTIPLE AD7768-1 DEVICES ADDITIONAL FUNCTIONALITY OF THE AD7768-1 Reset Status Header Diagnostics APPLICATIONS INFORMATION ANALOG INPUT RECOMMENDATIONS Recommended Driver Amplifiers ANTIALIASING FILTER DESIGN CONSIDERATIONS RECOMMENDED INTERFACE Initializing the Recommended Interface Recommended Interface for Reading Data Resynchronization of the Recommended Interface PROGRAMMABLE DIGITAL FILTER Filter Coefficients Upload Sequence Example Filter Upload Filter Upload Verification ELECTROMAGNETIC COMPATIBILITY (EMC) TESTING Radiated Immunity Radiated Emissions Electrical Fast Transients (EFTs) AD7768-1 SUBSYSTEM LAYOUT REGISTER SUMMARY REGISTER DETAILS COMPONENT TYPE REGISTER UNIQUE PRODUCT ID REGISTERS DEVICE GRADE AND REVISION REGISTER USER SCRATCHPAD REGISTER DEVICE VENDOR ID REGISTERS INTERFACE FORMAT CONTROL REGISTER POWER AND CLOCK CONTROL REGISTER ANALOG BUFFER CONTROL REGISTER VCM CONTROL REGISTER CONVERSION SOURCE SELECT AND MODE CONTROL REGISTER DIGITAL FILTER AND DECIMATION CONTROL REGISTER SINC3 DECIMATION RATE (MSB REGISTER) SINC3 DECIMATION RATE (LSB REGISTER) PERIODIC CONVERSION RATE CONTROL REGISTER SYNCHRONIZATION MODES AND RESET TRIGGERING REGISTER GPIO PORT CONTROL REGISTER GPIO OUTPUT CONTROL REGISTER GPIO INPUT READ REGISTER OFFSET CALIBRATION MSB REGISTER OFFSET CALIBRATION MID REGISTER OFFSET CALIBRATION LSB REGISTER GAIN CALIBRATION MSB REGISTER GAIN CALIBRATION MID REGISTER GAIN CALIBRATION LSB REGISTER SPI INTERFACE DIAGNOSTIC CONTROL REGISTER ADC DIAGNOSTIC FEATURE CONTROL REGISTER DIGITAL DIAGNOSTIC FEATURE CONTROL REGISTER CONVERSION RESULT REGISTER DEVICE ERROR FLAGS MASTER REGISTER SPI INTERFACE ERROR REGISTER ADC DIAGNOSTICS OUTPUT REGISTER DIGITAL DIAGNOSTICS OUTPUT REGISTER MCLK DIAGNOSTIC OUTPUT REGISTER COEFFICIENT CONTROL REGISTER COEFFICIENT DATA REGISTER ACCESS KEY REGISTER OUTLINE DIMENSIONS ORDERING GUIDE
