Datasheet AD8285 (Analog Devices) - 7
ОписаниеRadar Receive Path AFE: 4-Channel LNA/PGA/AAF with ADC
Страниц / Страница27 / 7 — Data Sheet. AD8285. ABSOLUTE MAXIMUM RATINGS Table 5. Parameter Rating. …
ВерсияB
Формат / Размер файлаPDF / 511 Кб
Data Sheet. AD8285. ABSOLUTE MAXIMUM RATINGS Table 5. Parameter Rating. ESD CAUTION
Data Sheet AD8285 ABSOLUTE MAXIMUM RATINGS Table 5 Parameter Rating ESD CAUTION
24 предложений от 14 поставщиков
Высокочастотная техника и средства высокочастотной идентификации ВЧ микросхемы и модули
Эиком
AD8285WBCPZ
от 2 853 ₽
AD8285WBCPZ
от 3 053 ₽
AD8285WBCPZ-RL
ЗУМ-СМД
AD8285WBCPZ
Data Sheet AD8285 ABSOLUTE MAXIMUM RATINGS Table 5.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a Electrical stress rating only; functional operation of the product at these AVDD18x1 to GND −0.3 V to +2.0 V or any other conditions above those indicated in the operational AVDD33x2 to GND −0.3 V to +3.5 V section of this specification is not implied. Operation beyond DVDD18x3 to GND −0.3 V to +2.0 V the maximum operating conditions for extended periods may DVDD33x4 to GND −0.3 V to +3.5 V affect product reliability. Analog Inputs −0.3 V to +3.5 V
ESD CAUTION
INx+, INx− to GND Auxiliary Inputs −0.3 V to +2.0 V INADC+, INADC− to GND Digital Outputs −0.3 V to +3.5 V D[11:0], DSYNC, SDIO to GND CLK+, CLK− to GND −0.3 V to +3.9 V PDWN, SCLK, CS, AUX, MUXA, −0.3 V to +3.9 V ZSEL to GND RBIAS, VREF to GND −0.3 V to +2.0 V Environmental Operating Temperature −40°C to +105°C Range (Ambient) Storage Temperature −65°C to +150°C Range (Ambient) Maximum Junction 150°C Temperature Lead Temperature 300°C (Soldering, 10 sec) 1 AVDD18x = AVDD18 and AVDD18ADC. 2 AVDD33x = AVDD33A, AVDD33B, AVDD33C, AVDD33D, and AVDD33REF. 3 DVDD18x = DVDD18, DVDD18CLK. 4 DVDD33x = DVDD33, DVDD33SPI, DVDD33CLK, DVDD33DRV. Rev. B | Page 7 of 27 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION RADAR RECEIVE PATH AFE CHANNEL OVERVIEW Low Noise Amplifier (LNA) Recommendation Antialiasing Filter (AAF) Mux and Mux Controller ADC CLOCK INPUT CONSIDERATIONS CLOCK DUTY CYCLE CONSIDERATIONS CLOCK JITTER CONSIDERATIONS SDIO PIN SCLK PIN CS\ PIN RBIAS PIN VOLTAGE REFERENCE POWER AND GROUND RECOMMENDATIONS EXPOSED PADDLE THERMAL HEAT SLUG RECOMMENDATIONS SERIAL PERIPHERAL INTERFACE (SPI) HARDWARE INTERFACE MEMORY MAP READING THE MEMORY MAP TABLE LOGIC LEVELS RESERVED LOCATIONS DEFAULT VALUES APPLICATION DIAGRAMS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
