Datasheet AD9271 (Analog Devices) - 6
| Производитель | Analog Devices |
| Описание | Octal LNA/VGA/AAF/ADC and Crosspoint Switch |
| Страниц / Страница | 60 / 6 — AD9271. AD9271-25. AD9271-40. AD9271-50. Parameter1. Conditions. Min Typ. … |
| Версия | B |
| Формат / Размер файла | PDF / 2.1 Мб |
AD9271. AD9271-25. AD9271-40. AD9271-50. Parameter1. Conditions. Min Typ. Max Min Typ. Max Unit
13 предложений от 13 поставщиков IC ADC 12BIT PIPELINED 100TQFP. 12 Bit Analog to Digital Converter 8, 16 Input 8 Pipelined 100-TQFP-EP (14x14). Data Acquisition -... |
| AD9271BSVZRL-40
| 5 855 ₽ | |
| AD9271BSVZRL-40 Analog Devices | 7 914 ₽ | |
| AD9271BSVZRL-40 Analog Devices | 11 485 ₽ | |
| AD9271BSVZRL-40 Analog Devices | по запросу | |
AD9271 AD9271-25 AD9271-40 AD9271-50 Parameter1 Conditions Min Typ Max Min Typ Max Min Typ Max Unit
POWER SUPPLY AVDD 1.7 1.8 1.9 1.7 1.8 1.9 1.7 1.8 1.9 V DRVDD 1.7 1.8 1.9 1.7 1.8 1.9 1.7 1.8 1.9 V CWVDD 3.0 3.3 3.6 3.0 3.3 3.6 3.0 3.3 3.6 IAVDD Full-channel mode 505 613 742 mA CW Doppler mode 136 160 170 mA with four channels enabled IDRVDD 46.7 48.7 50 mA Total Power Full-channel mode, 993 1063 1190 1280 1425 1494 mW Dissipation no signal (Including Output Drivers) CW Doppler mode 192 216 224 mW with four channels enabled Power-Down 4.5 4.5 4.5 mW Dissipation Standby Power 101.7 112.5 120.6 mW Dissipation Power Supply 1 1 1 mV/V Rejection Ratio (PSRR) ADC RESOLUTION 12 12 12 Bits ADC REFERENCE Output Voltage Error ±20 ±20 ±20 mV (VREF = 1 V) Load Regulation @ 3 3 3 mV 1.0 mA (VREF = 1 V) Input Resistance 6 6 6 kΩ 1 See the AN-835 Application Note, Understanding High Speed ADC Testing and Evaluation, for a complete set of definitions and how these tests were completed. 2 SE = single ended. 3 The overrange condition is specified as being 6 dB more than the full-scale input range. Rev. B | Page 6 of 60 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY PRODUCT HIGHLIGHTS SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS ADC TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS THERMAL IMPEDANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS EQUIVALENT CIRCUITS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ULTRASOUND CHANNEL OVERVIEW Low Noise Amplifier (LNA) Active Impedance Matching LNA Noise INPUT OVERDRIVE Input Overload Protection CW DOPPLER OPERATION Crosspoint Switch TGC OPERATION Variable Gain Amplifier Gain Control VGA Noise Antialiasing Filter ADC CLOCK INPUT CONSIDERATIONS Clock Duty Cycle Considerations Clock Jitter Considerations Power Dissipation and Power-Down Mode Digital Outputs and Timing SDIO Pin SCLK Pin CSB Pin RBIAS Pin Voltage Reference Internal Reference Operation External Reference Operation SERIAL PORT INTERFACE (SPI) HARDWARE INTERFACE MEMORY MAP READING THE MEMORY MAP TABLE RESERVED LOCATIONS DEFAULT VALUES LOGIC LEVELS APPLICATIONS INFORMATION DESIGN GUIDELINES Power and Ground Recommendations Exposed Paddle Thermal Heat Slug Recommendations EVALUATION BOARD POWER SUPPLIES INPUT SIGNALS OUTPUT SIGNALS DEFAULT OPERATION AND JUMPER SELECTION SETTINGS QUICK START PROCEDURE SCHEMATICS AND ARTWORK OUTLINE DIMENSIONS ORDERING GUIDE
