Datasheet RH1021-7 (Analog Devices) - 6
ОписаниеPrecision 7V Reference
Страниц / Страница6 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. Output Voltage. Load Regulation …
ВерсияF
Формат / Размер файлаPDF / 555 Кб
TYPICAL PERFORMANCE CHARACTERISTICS. Output Voltage. Load Regulation (Shunt Mode). Load Regulation (Sourcing). Line Regulation
TYPICAL PERFORMANCE CHARACTERISTICS Output Voltage Load Regulation (Shunt Mode) Load Regulation (Sourcing) Line Regulation
Three Terminal Voltage Reference, 1 Output, 10V, Trim/Adjustable, BIPolar, CDFP10
RH1021BMH-7
RH1021-7
7.01 60 18 VIN = 12V VIN = OPEN VIN = 12V IOUT = 0 0mA ≤ I 50 1.2mA ≤ IOUT ≤ 10mA 16 OUT ≤ 10mA 14 40 12 30 10 20 OUTPUT VOLTAGE (V) 8 6.99 LOAD REGULATION (ppm/mA) LOAD REGULATION (ppm/mA) NOTE 8 10 6 0 4 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE Krad (Si) TOTAL DOSE Krad (Si) TOTAL DOSE Krad (Si) RH1021-7 G01 RH1021-7 G02 RH1021-7 G03
Line Regulation Temperature Coefficient Minimum Current (Shunt Mode)
1.0 15 0.9 VIN = 12V VIN = OPEN 0.5 10 0.8 0 12V ≤ VIN ≤ 40V 5 0.7 –0.5 8.5V ≤ VIN ≤ 12V 0 0.6 –1.0 –5 0.5 LINE REGULATION (ppm/V) MINIMUM CURRENT (mA) –1.5 –10 0.4 TEMPERATURE COEFFICIENT (ppm/°C) –2.0 –15 0.3 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE Krad (Si) TOTAL DOSE Krad (Si) TOTAL DOSE Krad (Si) RH1021-7 G04 RH1021-7 G05 RH1021-7 G06 I.D. No. 66-10-0178 Rev F 6 10/18 www.analog.com ANALOG DEVICES, INC. 1990-2018 Document Outline Description Absolute Maximum Ratings Burn-In Circuits Pin Configuration Order Information Table 1: Electrical Characteristics Table 1A: Electrical Characteristics Table 2: Electrical Test Requirements Total Dose Bias Circuit Revision History Typical Performance Characteristics
