Datasheet AD605 (Analog Devices) - 10
ОписаниеDual, Low Noise, Single-Supply Variable Gain Amplifier
Страниц / Страница24 / 10 — AD605. –30. –35. VOUT = 1V p-p. VGN = 1.0V. c) B. –40. INPUT GENERATOR …
ВерсияF
Формат / Размер файлаPDF / 473 Кб
AD605. –30. –35. VOUT = 1V p-p. VGN = 1.0V. c) B. –40. INPUT GENERATOR LIMIT = 21dBm. TION. –45. –50. (dB. –55. HD3. HD2. –10. R A. –60. FREQ = 10MHz. –65. –15
AD605 –30 –35 VOUT = 1V p-p VGN = 1.0V c) B –40 INPUT GENERATOR LIMIT = 21dBm TION –45 –50 (dB –55 HD3 HD2 –10 R A –60 FREQ = 10MHz –65 –15
24 предложений от 20 поставщиков
ЧипСити
AD605BRZ-R7
365 ₽
AD605BRZ-RL
1 534 ₽
AD605BRZ-R7
от 3 806 ₽
AD605BRZ
AD605 –30 15 –35 VOUT = 1V p-p 10 VGN = 1.0V c) B –40 (d 5 INPUT GENERATOR LIMIT = 21dBm TION –45 ) 0 OR m T –50 IS (dB D IN –5 P IC –55 HD3 ON HD2 M –10 R A –60 H FREQ = 10MHz –65 –15
22
FREQ = 1MHz
25 0 0 1- 1- 54 54
–70
00
–20
00
100k 1M 10M 100M 0.1 0.5 0.9 1.3 1.7 2.1 2.5 2.9 FREQUENCY (Hz) VGN (V)
Figure 21. Harmonic Distortion vs. Frequency Figure 24. 1 dB Compression vs. VGN
–35 35 VOUT = 1V p-p –40 30 Bc) d –45 HD3 25 (10MHz) N ( f = 1MHz HD2 IO –50 (1MHz) HD2 Bm) 20 d RT ( f = 10MHz O (10MHz) T T P S –55 15 RCE C DI E NI –60 T 10 O IN M –65 5 HAR –70 HD3 0
6 23
(1MHz)
0 02 1- 1- 54 54
–75
00
–5
00
0.5 0.8 1.1 1.4 1.7 2.0 2.3 2.6 2.9 0.6 1.0 1.4 1.8 2.2 2.6 3.0 VGN (V) VGN (V)
Figure 22. Harmonic Distortion vs. VGN at 1 MHz and 10 MHz Figure 25. Third-Order Intercept vs. VGN at 1 MHz and 10 MHz
–20 2V f = 10MHz VOUT = 2V p-p –30 VOUT = 1V p-p VGN = 1.5V VGN = 1.0V –40 –50 ) –60 m IV B /D V (d –70 T OUP –80 –400m –90 TRIG'D –100 –110
7 24 0 02 1- 1- 54 54
–120
00
2V
00
9.92 9.96 10.00 10.02 10.04 253ns 1.253µs FREQUENCY (MHz) 100ns/DIV
Figure 23. Intermodulation Distortion Figure 26. Large Signal Pulse Response Rev. F | Page 10 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS (PER CHANNEL) THEORY OF OPERATION DIFFERENTIAL LADDER (ATTENUATOR) AC COUPLING GAIN CONTROL INTERFACE FIXED GAIN AMPLIFIER AND INTERPOLATOR CIRCUITS—APPLYING AN ACTIVE FEEDBACK AMPLIFIER APPLICATIONS INFORMATION CONNECTING TWO AMPLIFIERS TO DOUBLE THE GAIN RANGE EVALUATION BOARD INPUT CONNECTIONS ADJUSTING GAIN, COMMON-MODE, AND REFERENCE LEVELS OUTPUT CONNECTIONS OUTLINE DIMENSIONS ORDERING GUIDE
