Datasheet HMC1023LP5E (Analog Devices) - 5
Описание72 MHz Dual Programmable Low Pass Filter
Страниц / Страница34 / 5 — HMC1023LP5E. 72 MHz DUAL PROGRAMMABLE. LOW PASS FILTER WITH DRIVER. …
Формат / Размер файлаPDF / 2.0 Мб
HMC1023LP5E. 72 MHz DUAL PROGRAMMABLE. LOW PASS FILTER WITH DRIVER. Figure 7. Noise Figure, 1 k. Source. Impedance, 100
HMC1023LP5E 72 MHz DUAL PROGRAMMABLE LOW PASS FILTER WITH DRIVER Figure 7 Noise Figure, 1 k Source Impedance, 100
5 предложений от 5 поставщиков
Волновой фильтр и часть EMI/RFI, Active Filter Dual Low Pass 6th Order 72MHz 32Pin QFN
HMC1023LP5ETR
1 661 ₽
HMC1023LP5ETR
4 079 ₽
HMC1023LP5ETR
727GS
HMC1023LP5ETR
HMC1023LP5E
v01.0113
72 MHz DUAL PROGRAMMABLE LOW PASS FILTER WITH DRIVER Figure 7. Noise Figure, 1 k
Impedance Selected Figure 8. Filter Output Noise [3]
30 100 T 28 M 26 0 dB Gain 72 MHz 24 G - S 22 NOISE FIGURE (dB) 10 dB Gain OUTPUT NOISE (nV/rtHz) 10 IN 20 S 5 MHz S 18 5 7 10 14 20 28 40 50 72 0.001 0.01 0.1 1 10 100 E FILTER BANDWIDTH (MHz) FREQUENCY (MHz) C -40 C +25 C +85 C 5 MHz 28 MHz 7 MHz 40 MHz 10 MHz 50 MHz O 14 MHz 72 MHz 20 MHz R
Figure 9. Uncalibrated Figure 10. Uncalibrated Sideband Rejection, Sideband Rejection, 0 dB Gain 10 dB Gain
D P 60 60 N A 55 55 B dBc) dBc) 50 50 E S 45 45 A 40 40 SIBEBAND REJECTION ( Internal Input Impedance Setting SIBEBAND REJECTION ( Internal Input Impedance Setting 35 35 IF / B 30 30 0 1 2 3 4 5 6 7 8 0 1 2 3 4 5 6 7 8 FILTER BANDWIDTH (MHz) FILTER BANDWIDTH (MHz) 1000 W 400 W 100 W 1000 W 400 W 100 W
Figure 11. Arbitrary Bandwidth Setting 3 Figure 12. Output IP3, dB Cutoff Frequency Error [5] 72 MHz Bandwidth Setting, 0 dB Gain [6]
4 50 3 Opamp Bias = 00 Opamp Bias = 01 Opamp Bias = 10 40 2 1 30 0 20 -1 OUTPUT IP3 (dBm) -2 CUTOFF FREQUENCY ERROR (%) 10 B -3 3 d -4 0 0 10 20 30 40 50 60 70 80 0 10 20 30 40 50 60 70 FREQUENCY (MHz) ARBITRARY FILTER BANDWIDTH (MHz) Reg02h[1:0] = 00 Reg02h[1:0] = 10 Reg02h[1:0] = 01 [3] 100 Ω source impedance used, and input impedanceo of HMC1023LP5E set to 1 kΩ [4] 100 Ω input impedance into the HMC1023LP5E selected by writing Reg 02h[10]=1. [5] Used recommended OpAmp bias settings (Reg 02h[1:0]) in Table 9. [6] OIP3 and OIP2 measured from 100 Ω differential source into 400 Ω differential load. Used recommended OpAmp bias settings (Reg 02h[1:0]) in Table 9. OIP3 and OIP2 measurements can be translated from dBm into dBVrms as follows: IPx [dBVrms] = IPx [dBm] -4 dB. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
5
Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
